Old 26th December 2009, 05:55 PM   #1
valo is offline valo  Norway
valo's Avatar
Default symmetrisk gain clone
hey boys and girls, I have a small Christmas nut to you all ), I play alitle with a new cad program and the results you see below .. and now the big question will this work and play nice sound .. or shell I only to give up and grab a beer
http://www.polarboing.com
Old 26th December 2009, 06:51 PM   #2
is it a BPA200 with inverting amplifiers?
Where are all the other components?
What values are R1, R2, R3 & R4?
How does the DC offset vary with temperature?
What happens to the amps when DC offset is not zero.
regards Andrew T.
Old 26th December 2009, 07:02 PM   #3
valo's Avatar
R1,R2,R3 & R4 i guess will be 10k
R9,R10,R11, & R12 is 221
R5,R6,R7 & R8 is 0.1
i plan to use opa541 chips, and i dont have a clue what will happen when det offset is not zero ..
Old 26th December 2009, 07:11 PM   #4
you guess wrong.
If R1 =10k and R12=221r then gain is 221/10000 =0.0221 ~-33dB
Since you have a bridged load, the effective gain at the load is -27dB.
Swap these around and the gain becomes 10000/221 =45.2 ~+33dB and across the load +39dB. This is very high.
Swapping the resistor values causes an input impedance problem. The XLR sees an Rin=110R. What can drive 110r?
regards Andrew T.
Old 26th December 2009, 07:29 PM   #5
valo's Avatar
okidoki, well i dont have a clue what Im doing but i joined this forum to learn and for fun .. this is my verry first circuit i have drawn inspirert av varius deisigns i have seen here in the forum ..
so Im happy for all the help i can get
Old 26th December 2009, 07:35 PM   #6
download the opa datasheet.
read it front to back twice.
Come back with questions.
Forget about a BPA in the meantime. Settle for a single channel non-inverting amp based on the opa instructions.
regards Andrew T.
Old 26th December 2009, 08:35 PM   #7
valo's Avatar
Matthew Cattle's Website This is allmost the same drawing that i have with the same resistors values
Old 26th December 2009, 11:28 PM   #8
Shenda is offline Shenda  Bosnia and Herzegovina
Shenda's Avatar
Incorrect!
This is almost the same drawing that you have...
... but with the different resistors values!
Gain clone testing stcboy Chip Amps 3 2nd August 2008 03:27 PM
New gain clone transformer Ted205 Chip Amps 1 8th July 2008 01:24 PM
Yet another 3886 gain clone! ianpengelly Chip Amps 56 9th December 2007 01:59 PM
For all Gain Clone fans................. ashok Chip Amps 21 27th June 2004 11:07 PM
What is a Gain Clone exactly? Lars Clausen Chip Amps 33 26th November 2003 05:33 PM
Page generated in 0.08502 seconds (80.56% PHP - 19.44% MySQL) with 10 queries
