Old 24th December 2009, 10:41 AM   #1
Robzy is offline Robzy  Australia
Default Which chipamp for car audio
Hey guys, I have a 60 year old car (Morris Minor Convertible) that currently has an ancient tuner hooked up to an old crappy speaker sitting on a parcel shelf. (Both added by a previous owner)
I'm wanting to upgrade this on the cheap, and realising I have a couple of spare computer satellite speakers here thought they might do well. They are ideal since they're already mounted in enclosures, albeit cheap crappy plastic, and that means I won't have to actually modify the car at all.
One thing I'll be needing though is an amplifier, and I was thinking a nice simple chip amp. To keep things simple, too, I'm hoping to be able to use the 12v car battery without stepping it up at all - in order to get the most out of such small voltage I will certainly be bridging.
But that's left me wondering if there's a single chip amplifier out there that will do the job. I've researched the LM3886 but the minimum voltage is much greater than 12V, and can't go anywhere near rail-to-rail.
Are there any chips out there that will handle a 12V power supply and be able to run close to rail-to-rail?
Thanks,
Rob.
Old 24th December 2009, 12:20 PM   #2
you need an amp chip that is designed to work on 12V to 14V single polarity supply.
regards Andrew T.
Old 24th December 2009, 12:22 PM   #3
Heh, yes, I know that - I was hoping for some suggestions.
Rob.
Old 24th December 2009, 12:27 PM   #4
cjkpkg is offline cjkpkg  United States
I have ordered two of Arjen Helders TA2024 tripath amps for this very purpose. I plan to build a 4ch amp.
These boards run from a +12V and ground power schema.
LINKY
Old 24th December 2009, 12:34 PM   #5
Oh wow, that looks pretty good. The problem is that since I will be using 8ohm speakers, I will only really have 6W per channel available.
Is 6W/channel enough for car audio?
Rob.
Old 24th December 2009, 01:50 PM   #6
blueskynis's Avatar
Send a message via MSN to blueskynis Send a message via Yahoo to blueskynis
Have a look at:
Philips
TDA1562Q 70W
TDA155xQ from 4x6W to 2x22W
TDA8560Q 2x40 @2 ohm
TDA8568Q 4x25W
from ST
TDA7374b 2x22W
TDA7375 2x22W
TDA7454 4x35W
TDA7560 4x45W
That's what I can think on for now. THD is approx 10% at mentioned output power.
Cheers
Windows-free with Linux
== blueskynet.dyndns-server.com ==
Old 24th December 2009, 02:56 PM   #7
Thanks blueskynis.
Out of curiosity, though, what's an acceptable level of THD? I would've thought that <1% would be where it's at...
Rob.
Old 24th December 2009, 08:21 PM   #8
The beauty of Arjen's boards is that they are generally considered VERY good in sound and quality and very inexpensive - just add power and a couple RCA jacks and you are ready to go...
Sure the TA2024 might me a little anemic for some but I'm pushing 40 and I just want a nice sounding system in my car...I refuse to pay hundreds of $$$ for an amp and all that...
I have a set of Blaupunkt separates in the front and a pair of Infinity kappas in the rear doors.
I just want nice crystal clear sound from my HU...I dont need to rattle any windows...
Old 25th December 2009, 12:51 AM   #9
Oh, don't get me wrong, window rattling is not what I'm going for - but I'm wondering if 6W is enough power to simply hear it properly considering...
- I'm using small inefficient sealed computer speakers
- They will be sitting on a parcel shelf, with quite a few obstructions and roundabouts to my ear
- This is in a 60yo car with more engine noise than usual (although not a whole lot more)
- It's a convertible, and there can be a bit of noise from the wind and surrounding traffic
Although, I guess for AUD$18 it can't hurt to buy and try.
Rob.
Old 25th December 2009, 02:07 PM   #10
blueskynis's Avatar
Pick a single chip mentioned above and you will have around 2x10 watts of decent power at 8 ohms. I would go for TDA7374 or 7375. I had 2xTDA1553 in my old car and they did their job nicely, pretty good sounding too.
Used Car Audio Madmike2 Swap Meet 3 5th February 2009 03:31 AM
Home Audio w/ Car Audio Sub? Werd@# Subwoofers 1 23rd November 2004 05:28 AM
Page generated in 0.11623 seconds (80.20% PHP - 19.80% MySQL) with 10 queries
