| Chip Amps Amplifiers based on integrated circuits |
#21 | |
solder at component side - its a double layer PCB, so u have copper in both layers. and chipamp is a professional PCB provider, he use more sophisticated machines for PCB making ![]() ( i guess u are quite new in this field ) -By the way i feel 5 mins of heat is too high. My setting is 1.5 mins with normal amount of pressure. Keep 10 layers of newspaper below pcb, then place the pcb with copper side facing on top, put the glossy paper and again keep 6-8 layers of newspaper. and try to keep PCB small enough so that it can be contained with in the cloth iron. just apply for 1.5 mins at full heat and moderate hand pressure.
. . .. ... ..... ........ ............. ..................... .................................. My Blog
#22 | |
I might have missed it, but did you thoroughly clean the copper of the PCB? I thoroughly scrubbed the copper side with a synthetic scrubbing pad and then cleaned with 99% rubbing alcohol or acetone with white paper towels until the paper towels stopped picking up dirt. This took several minutes.
I then printed from expresspcb on some glossy ink jet paper in my laser printer. I'm using a brother laser with a brother toner cartridge. If you get no toner transfer, you are printing on "ink jet" paper using a "laser printer", correct? That's the only way this method works. I actually tape the PCB to the the glossy paper before ironing to ensure the paper doesn't move with respect to the PCB. I had the iron on "high" or "cotton" setting and made sure I the whole board got evenly heated and made sure to use the nose of the iron to press on the traces to help. This should only take a few minutes. It worked like a charm for me. In fact the paper lifted away immediately without soaking. I ended up couple minor pinholes and there was some paper material between closely spaced traces that I used a blade to remove. Quote:
#23 |
It sounds like pra3718 either didn't get the board cleaned well-enough or didn't use enough pressure with the tip of the iron. It also is necessary to roughen the copper surface a little bit, before you clean it, with a very fine-grain abrasive, such as a fine-grain synthetic scrubbing pad.
And it's not "equal pressure...to all parts of the pcb" that you want, pra3718. Keeping the iron flat is usually not enough pressure. So (after heating the whole thing with the iron flat) you should probably try using just the part near the tip of the iron, and move it across only part of the board at a time. You would basically be moving it along "rows and columns", i.e. vertical strips of the board and then horizontal ones, reheating the whole board periodically if necessary (maybe necessary for large boards; it's "trial and error" until you get a feel for it.). At least you can always wash the toner off with Laquer Thinner and start over. Cheers, Tom Gootee |
#24 |
Yes, this time done it.
1) Artwork printing should be FULL-IN-DARK-MODE. 2) Copper side board should be cleaned. 3) "Keeping the iron flat is usually not enough pressure. So (after heating the whole thing with the iron flat) you should probably try using just the part near the tip of the iron, and move it across only part of the board at a time" that's true. This way I can make PCB at home. But sorry, not professional looking. it looks like home-made pcb. I never tried screen printing but toner transfer & screen printing method should be in same result. or what ? I wish to know how to make professional looking pcb? |
#25 |
Hey, why don't u try my LM3886 diy PCB, Another Single Sided DIY PCB for LM3886 + Power Supply is the link.
just print the pdf and transfer it on copper board ![]() And i asssure you , with toner transfer method , u can make high quality PCBs.
#26 |
Yep, you can count on it. The final result will look very good.
Any solution is a compromise. |
#27 |
All of you may not be wrong. I will try again.
#28 |
A way to make it even easier is to Google "Press n Peel Blue" from techniks dot com.
Using a laser jet you print on the rough side. Using a stanard iron at just below steam transfer it over to the clean pcb. The attached photo is a recent board I made for another project using Eagle light and the press n peel. The traces in this case are pretty thick, but I have made then as small as 0.05 before without too much problem. It works ALOT better than simple toner transfer.
Living Life Doing the Waltz in 4/4 meter. |
#29 |
Thank you SGregory for adding "Press n Peel Blue" idea. I will try my level best if it is available in India & my city.
#30 |
Hello friends and gurus,Iam new here. Can any one say where i can get pcb clads for my projects. Iam staying in south India, Andhra pradesh. Please sirs Iam in need of it mostly. If any one of u sent me in corrier I can pay. Please help.
| Etching PCB:s | Loial | Parts | 105 | 12th April 2012 03:22 AM |
| Calculations for PCB etching solution. | juma | Parts | 24 | 18th December 2006 08:43 PM |
| Problem with etching PCB!!! Please help! | safetyman | Parts | 20 | 16th May 2006 05:35 PM |
| ENX bulb for PCB etching? | Stocker | Everything Else | 0 | 6th May 2006 02:22 AM |
| Etching 4oz PCB boards | kiwi_abroad | Parts | 4 | 28th June 2003 09:09 PM |
