| Chip Amps Amplifiers based on integrated circuits |
#11 |
After learning expresspcb I am facing a problem. I have seen lot-off threads which claims the attached pictures are ready for etching. For example LM1875 shows pin 1 is left side, if i etch, and turn the pcb at component side pin 1 would be right side. How should I proceed?
#12 |
Don't you have an option to 'mirror' the print out ?
Use 2 parts H2O2 ( Hydrogen peroxide) ( bought from a chemist ) to 1 part HCL solution bought from a regular supermarket or the corner grocery store. called ' cleaning acid for cleaning purposes. Works VERY fast . Be careful about the HCL fumes and I think you MUST look up the web for safe usage of HCL even in solution form. Complete etching takes place in about 3 minutes or so ! As for printing using the Laser printer method ( inkjet will not work). Use high quality glossy paper from product brochures ( cheap ) or better still some low cost photo printing paper. It needn't be glossy but make sure you print on the correct side. You might need to try ironing on the image a few times to get the hang of it. If it comes out bad, clean the surface with paint thinner and do it again. I touch up errors with nail polish diluted with amyl acetate ( or nail polish remover ). Make sure you do NOT reverse the image. The image must be what you see on screen ( from the component side). When you iron it on it gets reversed ! CHECK the image that you ironed on to the copper board BEFORE you etch. Make sure it isn't reversed.
AM |
#13 |
I get good results using an inkjet and this,
http://www.megauk.com/datasheets/521...ons_(0807).pdf
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#14 |
Is that an 'iron on' film ? The laser printer method is an 'iron on method'. No need for any exposure to light etc.
AM |
#15 |
Toner transfer method obviously works only if you print with laser printers or copy machines. I also use this method and print the PCBs on glossy magazine covers instead of buying PnP dedicated foil. I managed to get traces as thin as 14mills.
Any solution is a compromise. |
#16 | |
It's a transparency, so use a UV light box. No problem going down to very fine print sizes such as for surface mount.
#17 |
Yes I mean't the JetStar film .
With the toner method you don't need any expensive paper or a photo sensitive coating on the copper laminate. Just a good laser print on paper (as explained) and a plain clean copper laminate board. No exposing time either just time to 'iron it on' !
AM |
#18 |
Toner transfer method is the best for DIY starters, but u need a little practice to get "right" time, heat and pressure to use with iron. I had made many gainclone PCBs just like this only.
just check it - DIY Audio Amplifier Blog: Making Gainclone PCB at Home. and - DIY Audio Amplifier Blog: Make@home PCB drill. |
#19 | |
Okey. Today I tried, but all circuit does not appear on pcb. I think there is no confusion till circuit printed on glossy paper. Please find what is my mistake. 1) I put pcb copper side up on the piece of MDF. 2) printed glossy paper, printed side at copper. 3) Put the iron on the paper upto 5 min. ( There is no way to find circuit appear on pcb or not. Because paper stick with pcb. If circuit not appear on pcb more heat required ) 4) After 5 min. I found glossy paper is still white, (means, heat does not effect) PCB becomes very hot & little BEND. after 2 min I put it in full glass of water. After 10 Min glossy paper removed very easily but few part of circuit does not appear on pcb. I think, equal pressure & heat is required to all the area of pcb. OR what ? |
#20 |
I visit DIY Chip Amplifier Kits, PCB's, Components and Information. and found lm3886 pcb it is
a) Red color ( Is that paint or what is ? ) b) Solder at component side ( How is it possible ? ) c) DIY Chip Amplifier Kits, PCB's, Components and Information. is also make pcb by this toner procedure ? |
| Etching PCB:s | Loial | Parts | 103 | 16th April 2007 09:05 PM |
| Calculations for PCB etching solution. | juma | Parts | 24 | 18th December 2006 09:43 PM |
| Problem with etching PCB!!! Please help! | safetyman | Parts | 20 | 16th May 2006 06:35 PM |
| ENX bulb for PCB etching? | Stocker | Everything Else | 0 | 6th May 2006 03:22 AM |
| Etching 4oz PCB boards | kiwi_abroad | Parts | 4 | 28th June 2003 10:09 PM |
| Page generated in 0.10758 seconds (78.97% PHP - 21.03% MySQL) with 11 queries |
