Old 15th December 2009, 03:05 PM   #1
Default Lm3886 pcb
Just thought I would drop an LM3886 PCB layout for others to use.
I have built it and can verify that it does work.
Any suggestions on improving it will be appreciated.
3886 6.pdf
3886 7.pdf
3886 8.pdf
Old 15th December 2009, 03:14 PM   #2
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Very nice looking layout.
What did you use to route your board?
Old 15th December 2009, 06:40 PM   #3
CJ900RR is offline CJ900RR  Sweden
Nice layout.
It's routed with Eagle. You should provide a schematic and also make the copper around the pads bigger, cause Eagles original are a pain to solder, specially if you etch them at home.
Old 15th December 2009, 07:01 PM   #4
Hi Merlin
I used Eagle lite and did the routing manually.
I have picked up some mistakes so far
- The lower 1000uF cap needs to be reversed so that -ve is on the edge
- The 100uF cap needs to be reversed
- The 47uF cap needs to be reversed
Wizard
Old 16th December 2009, 04:36 AM   #5
ratza is offline ratza  Romania
ratza's Avatar
Very nice. How do you make those copper islands in Eagle? Polygons, by any chance?
Any solution is a compromise.
Old 16th December 2009, 06:45 AM   #6
Hi Ratza
Islands made using overlapping tracks. You don't want to see the error report, but hey it works.
Attached are the corrected layouts with pads slightly larger.
3886 6.pdf
3886 7.pdf
3886 8.pdf
Old 16th December 2009, 07:00 AM   #7
ratza's Avatar
Thanks Wizardmaxx. I asked because I use polygons and it never crossed my mind that round edges can also be used
Old 16th December 2009, 07:01 AM   #8
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Dont you think the power and GND traces a bit thin?
Best regards,
Ozgur
Old 16th December 2009, 11:03 AM   #9
ratza's Avatar
They're not. Mine are 80mills in width and they widstanded an unwanted short between a rail and GND. I have a 400VA toroid and 22Vca per rail. That's translated in alot of current in case of short circuit (9A between rails or 18A per rail).
Old 28th December 2009, 06:41 PM   #10
Hi wizardmarxx;
Can you provide the schematic? Regards
My Best DIY LM3886 sukyone Chip Amps 20 7th July 2007 01:35 AM
I need a little LM3886 help segasonicfan Chip Amps 30 22nd September 2005 03:06 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
what about this lm3886 pcb b<ben>n Chip Amps 6 27th June 2004 07:52 AM
Page generated in 0.09889 seconds (77.93% PHP - 22.07% MySQL) with 11 queries
