| Chip Amps Amplifiers based on integrated circuits |
I just want to show what I’ve been putting together. This is my first ever amplifiers build. When I started I didn’t know the difference between a capacitor and an inductor. I’m far from sure that this implementation is a good one but as far as I can judge I think it sounds pretty ok
![]() I had a 300 VA 30 V trafo to start with and I dident whant that high voltage why I chosed to use Carlos Phillipes regulated PSU. ![]() It turned out like this. ![]() ![]() When it comes to the amplifier part I looked at RJM Audio and have used his schematic but with some minor modifications to fit LM3876. ![]() After serveral tries I was finally satisfied with this small cuties. ![]() ![]() Each heat sink has thermal resistance of 1,85 C/W. ![]() ![]()
#2 |
#3 |
You forgot the most important thing! How does it sound?
#4 |
I left that part out on purpose. I am not an expert listener and don’t have so much to compare with. But I can compare it with a cheap compact system which I had home for a while and yes, there is big difference. Today I use it with a pair of Bjohannesens TABAQ. The sound is, compared to the compact system, very clean and detailed with good bas performance. I don’t really have anything to remark on. I am very satisfied over all.
There is no humming, no clicks and it is quiet between songs. There is only a very low ambient ssss-sound coming out of the speaker an on full volume you cant hear it 2 feet away from the driver. However I don’t have any view if it is h hifi or not, but I hope it is
#5 |
Honestly it does not matter in my mind if it's "hi-fi" or not, aslong as you are happy with the sound. I will be making my own gainclones eventually and it'll be fun to compare it to my NAD surround receiver.
You do however need to toss it into a box of somekind, looks a bit... naked :P |
#6 | |
![]() I'm almost sure that the noise comes out from the source.
Any solution is a compromise. |
#7 | |
#8 |
#9 |
looks like you could use a longer bit
#10 |
- or a different tool, like a saw perhaps
| help with b1 + gainclone build | crappyjones123 | Pass Labs | 4 | 25th June 2009 09:56 PM |
| Intro thred | Robert@Zapco | Introductions | 3 | 28th February 2008 04:31 PM |
| HELP First Amp Build - Gainclone? | Deagle50ae | Chip Amps | 7 | 12th April 2005 05:12 PM |
| LM3876 Gainclone, Bass shy | goldyrathore | Chip Amps | 18 | 5th March 2004 02:15 AM |
| No output of a LM3876 GainClone??? | Cradle22 | Chip Amps | 6 | 17th January 2003 10:26 PM |
| Page generated in 0.10398 seconds (83.31% PHP - 16.69% MySQL) with 10 queries |
