Old 6th December 2009, 08:42 PM   #11
take a look at the tda2050/lm1875 discussion thread,
Tda2030 vs lm1875
the tda 2050 is 25watts into 8ohm and 32watts into 4ohm. if you bridge into 8ohm to get 50watts thats 25 per chip into 4ohms from the data sheet you would need +/- 15 volts. (at full input voltage!)
hope this helps, happy soldering, steve.
Old 7th December 2009, 01:30 PM   #12
chingyg is offline chingyg  South Africa
I have ordered the TDA2050's they cost abt 1$ here. Can I put 4 of them on a CPU heatsink with a fan, will it be good enough for cooling?
Old 7th December 2009, 08:08 PM   #13
depends what the cpu cooler is from, and if you are going to run the fan? around 50mm x 50mm x 75mm was good enough for me running 4 chips, with the fan running at about 40% speed with a simple opamp pwm control.hope this helps, steve.
Tone control pre-amp digi01 Chip Amps 16 13th June 2011 07:18 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
GIGA AMP TDA2030 single(or)bridge with tone control & mic myanmar Chip Amps 5 6th February 2007 06:28 AM
Tone Control for my GC aditaquil Chip Amps 5 6th January 2005 11:39 PM
TI's Tone control JhonDoe Chip Amps 26 13th July 2004 01:29 AM
Page generated in 0.05228 seconds (78.34% PHP - 21.66% MySQL) with 11 queries
