pllxo w lm3886?
pllxo w lm3886?
Old 5th December 2009, 03:14 AM   #1
mrkramer is offline mrkramer  United States
Default pllxo w lm3886?
Hi all,
I am hoping to implement a passive line level xo like the one shown here: Passive High-Level Crossover
to drive 2 pretty basic lm3886 amps. 2nd order cross at around 80hz. I am not using an active preamp, just a 50k stepped attenuator. Will this combo work? Work well? Do I need to run an active pre?
Any help is appreciated,
MrKramer
Old 5th December 2009, 01:15 PM   #2
you cannot get a 2pole from a passive circuit unless you combine capacitors and inductors.
You can get 1pole from passive using R+C or L+C.
The R+C is usually adopted.
For the passive filter to work correctly, it must be fed from a zero ohm source impedance and it must feed into an infinite load impedance.
That Rsource and Rload requirement demands some active stages.
Decide if you want passive + active stages or go straight to active filter.
regards Andrew T.
pllxo w lm3886?Hide this!Advertise here!
PLLXO (v AXO v PXO) benefits/ Model? rick57 Multi-Way 42 10th August 2011 12:12 AM
PLLXO implementation lbstyling Multi-Way 14 29th September 2009 01:58 PM
Calculate PLLXO audiobomber Multi-Way 5 22nd August 2007 06:34 PM
Using phono input with PLLXO mashaffer Subwoofers 0 14th August 2007 12:36 AM
PLLXO high pass Soulwax Multi-Way 8 6th May 2005 01:40 AM
Copyright ©1999-2017 diyAudio
