| Chip Amps Amplifiers based on integrated circuits |
#2 |
Nice heatsink ... That should be plenty big enough ....
#3 |
Nice one, should be able to make a pretty small unit all being well.
#4 |
Take a look at this.... ESP - Heatsink design and transistor mounting
#5 |
Make sure it's lifted so the holes aren't blocked at the bottom. You need free air flow through it.
#6 | |
is that two channels of single bridged 4780? i.e. br100+br100?
What is the speaker impedance? What is the +-DC supply voltage? from National datasheet Quote:
regards Andrew T. Last edited by AndrewT; 5th December 2009 at 01:05 PM. |
#7 |
My plan is to have the 2 amps, both bridged.. I will be running a 300va 2x12v torodial. I would like to fit it all into a 8" wide box. However it is my first project and I'm kinda makin it up as I go along.
I will be happy to have a working kit at the end, then I can have a go at another. |
#8 |
what is the open circuit voltage of the 12Vac transformer when fed with your nominal mains supply voltage?
Look at the graph p10 bottom right, 4r0 and +-20Vdc. at 1.5W into 4r0 the single channel dissipates ~20W to the heatsink. the 4780 chip in bridge mode will dissipate ~40W to the heatsink when it delivers 3W into 8r0. It will be even hotter driving a real speaker. That 40W from a 4780 through the thermal resistance of 0.8C/W Rth j-c raises the junction temp about 32Cdegrees above the Tc temp. The Rth c-s of ~0.9C/W raises the case temp above the sink temp by about 36Cdegrees. Now Tj~Ts+68C A sink with two 4780 has to dissipate ~80W for an output of 3W+3W. If you select a sink with Rth s-a of 2C/W then Ts will be about 160Cdegrees above ambient temperature If that sink you have chosen is inside your chassis, the ambient temperature may be anywhere between 40degC and 100degC. Now, let's add these temperature drops up:- Ta=40degC, Ts-a=160Cdegrees, Tc-s=36Cdegrees, Tj-c=32Cdegrees giving Tj~268degC when the two chips are delivering 3W+3W into 8r0+8r0 from +-20Vdc supplies. Find a bigger heatsink. Do the sums for the proposed giant heatsink. Tell us what you find about Tj when output power is 3W+3W into 6ohm speakers and supply is +-17Vdc. I get the impression you have not checked any arithmetic relating to your bridged proposal. I have a temperature standard for a chipamp. I must be able to hold my finger on the chip without discomfort when it is operating at typical SPL levels with my typical music using my speakers with my typical audience @ my typical ambient temperature.
regards Andrew T. Last edited by AndrewT; 5th December 2009 at 01:43 PM. |
| How To Heatsink | pacificblue | Chip Amps | 23 | 12th February 2009 10:36 AM |
| heatsink | fligti91 | Pass Labs | 2 | 1st December 2008 05:07 AM |
| ZV9 Heatsink | dviswa | Pass Labs | 9 | 28th July 2006 02:43 AM |
| Page generated in 0.10311 seconds (79.24% PHP - 20.76% MySQL) with 10 queries |
