Old 14th April 2011, 03:09 PM   #31
Question About L1 on the schematic
Thanks for your attention
I have some doubts about your amplifier:
About the L1, how many turns and what is the diameter and which wire to use?
With these power transistors what power i will have and whats the minimum impedance?
Thanks in advance.
Old 14th April 2011, 03:52 PM   #32
would it not be tempting to separate the power supplies to the input/voltage amplifying stages (pins 7 &8) from the output power stages (pins 13 & 15)? as it has been designed in, and all the pcb's and built amplifiers I have seen don't have this, it may be worth trying. Someone may like it!
Old 14th August 2011, 11:39 AM   #33
Hi sir wizardmaxx,
I am new here and i read your post about your TDA7294 amplifier. and i am interested of it and i want to try to build this circuit, can you give me complete parts list of your TDA7294 amplifier, tnx in advance sir...
Old 11th January 2012, 08:28 AM   #34
flaotte is offline flaotte  Lithuania
Can I power TDA7294 with single supply +47 VAC transformer? Does anyone have circuit for that?
I would make middle point with resistors. Would it work or do I need to get better middle point?
Greetings - New Member Checking In Moke Introductions 1 6th August 2008 01:51 PM
Help please checking my B+ design gary h Tubes / Valves 26 17th July 2008 01:49 AM
Checking ARC SP9 Pathmark Tubes / Valves 2 11th December 2007 04:03 PM
Checking in... ghudnub Introductions 1 19th September 2005 03:58 PM
Checking used capacitor chris ma Everything Else 7 24th June 2003 12:59 AM
Page generated in 0.07056 seconds (71.78% PHP - 28.22% MySQL) with 11 queries
