Old 8th December 2009, 10:16 AM   #11
Atilla is offline Atilla  Norway
Soldering Gun Fanatic
Originally Posted by AndrewT View Post
no!
if the input offset is zero then there is a residual output offset. This is the input offset current times Rin times stage gain.
If there is an input offset, the residual offset and the input offset add (algebraically) together.
Sorry, my bad, AndrewT is correct. I was hasty at replying.
Old 8th December 2009, 12:37 PM   #12
The AC coupling of the input can be at EITHER the source or at the power amp, but not both.
Nearly all commercial sources have AC-coupled outputs, and most amps have AC-coupled inputs, because AC-coupling is the safer solution. Having both the source and the amp AC-coupled may be unnecessary, but it does not hurt from a safety point of view.
From a sonic point of view it is preferrable to either have only one filter or have the same corner frequency on all filters, if there are several. Lamentably there is no norm, regulation or even agreement among manufacturers that would ensure that.
Only few non-pro amps have a selector to choose from AC- and DC-coupled operation. With such a selector you still need a schematic or to open up the sources to find out whether they are AC- or DC-coupled. Then you have to instruct everybody, who may use the amp, which source needs AC- and which DC-coupling.
The two ways out of this are
- AC-couple the amp, like most manufacturers do. Simple, cheap and reliable.
- use a source selector with an additional contact layer that you can hardwire for the right setting with each source. Takes a more expensive selector and/or additional relays in return for a sonic improvement that is hardly noticeable, if at all. And don't forget to check and maybe rewire the circuit, when you replace a source.
If you've always done it like that, then it's probably wrong. (Henry Ford)
weird hum problem audiopro Tubes / Valves 4 31st August 2008 08:16 AM
NAD 306 weird problem Juko Solid State 1 4th May 2007 08:21 AM
Weird Amp Problem Stewart8989 Car Audio 3 6th April 2007 06:54 AM
Weird PSU problem phn Power Supplies 8 6th February 2007 02:42 AM
LM3886T Problem, I think Panelhead Chip Amps 5 28th December 2005 10:08 AM
Page generated in 0.06915 seconds (71.10% PHP - 28.90% MySQL) with 10 queries
