Old 21st December 2009, 05:16 AM   #31
tb46 is offline tb46  United States
Hi Y'all,
I was just think about building another LM3886 amplifier (after a long time) when I ran into this thread, thanks all, great stuff.
danielwritesbac,basically, you got it right.
In general the resistor at the non-inverting of an opamp is used to balance the dc offset. The rule of thumb for the value of this resistor is the parallel combination of the feedback resistors connecting output to inverting input to ground. This resistor is also a known noise source.
A capacitor connected in parallel to this resistor will not affect the dc performance, but will roll off (short out) the higher frequency signals at the positive input.
As a probably dumb question: "Has anyone tried this circuit with feedback components that are more in line with the values recommended by National Semiconductors, and reflected in standard implementations of the LM3886 as e.g.: the Elektor version?" It may well be that changing the design feedback components by an order of magnitude worsens the transient behaviour of this circuit. As Tom (gootee) seems to point out it is back to the seventies and all the fine discussions about slewrate and TIM.
Oliver
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 22 22nd November 2009 02:34 PM
LM3886 x 2 in parallel jmar Chip Amps 46 24th October 2009 03:53 PM
LM3886 in parallel Denis.BR Chip Amps 11 12th August 2009 07:16 PM
LM3886 Parallel Use Rachel Chip Amps 71 2nd July 2006 04:24 AM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.06213 seconds (67.90% PHP - 32.10% MySQL) with 10 queries
