| Chip Amps Amplifiers based on integrated circuits |
A buddy and I are doing a little experiment. We are building two gainclone amps. With his he is going cheep, and with mine I am trying to upgrade the components where it seems to make sense. We have almost everything figured out except which input capacitor to use for the upgraded amp. He is of the mind set that the input capacitor will not make much of a difference. To tell you the truth I don't know enough to have an opinion. I do know as I read through this forum about input capacitors there are some people that think strongly that these capacitor will make a difference.
So which input capacitor should I use. He estimates that I will need a capacitor 3 UF and 25 volts. Thanks Steve |
#2 |
Whats your input load (Rb) resistor?
If its 20-22K then 4,7uF is enough. But a solid type capacitor (MKS, MKT, MKP) strongly recommended istead of electroytics.
Best regards, Ozgur |
#3 |
just another
If possible go with a polypropylene cap. It will be big in comparison to electro's or polyester but they have much lower dielectric absorption which should result in better sound, especially when directly in the signal path.
I haven't tryed them myself but I've seen people say you can't beat the mudorf m-caps for value for money Wima MKP-4 are quite a bit more expensive, but are not what would be regarded an audiophile cap... I personally use some no name polypropylenes in my amp But for the best chance of hearing a difference make sure you friend uses cheap bi-polar electrolytics or polyester (greencap) caps as the input caps Tony. |
#4 |
Thanks guys. this is what I love about this forum.
#5 |
Hey....I have some MPTA(Metallized polypropylene for AC applications) caps lying around. Can these be used instead of the regular MPT ones?
Let There Be Music. |
| newbie capacitor question | milen007 | Parts | 6 | 5th May 2008 05:17 PM |
| Very Newbie Question - Is this a electrolytic capacitor? | zBuff | Parts | 1 | 11th July 2006 03:05 AM |
| Newbie capacitor question | The Nephilim | Multi-Way | 13 | 16th June 2005 10:57 PM |
| Input Capacitor | Shaz | Chip Amps | 3 | 20th September 2003 07:39 PM |
| Newbie: Aleph2 Capacitor Question | acliao | Pass Labs | 3 | 5th June 2002 03:31 AM |
| Page generated in 0.09889 seconds (66.86% PHP - 33.14% MySQL) with 10 queries |
