Old 25th November 2009, 01:58 PM   #1
Smile STKXXXX Vs LMXXXX
Hi All,
I am planning to build a subwoofer. I am not having much knowledge regarding amplifiers but know how to assemble one.
I already own a STK4141 based amplifier powered by a 20v 5A transformer and i found the sound was a bit OK.
Here is my doubt.
I am seeing a lot discussion going in here about the LM series(LM3886 specifically).
For the new sub which i am going to build which IC i can opt for?
Can it be a one from STK series or LM series?
The rectified voltage o/p of a 20v 5A transformer is around 36v. Is that enough to power up my SUB or I have to opt for a better power supply?
Also i had seen a lot of discussion regarding sub-woofer box design and could not come to a conclusion of which one to use
Please tell me which will be best design or lead me to some good resources regarding the building of Subwoofer boxes.
Basically i will be using a 4ohms - 10" or 12" Sub with 100w RMS as i could not find a better one here in INDIA.
Friends from INDIA... this is a question for you....
Which is the good sub available in INDIA?
I own a DAINTEE 10" sub but still not satisfied with its performance. Which is a best woofer available in INDIA?
Please clear my queries.....
Rg,
Ela
Old 25th November 2009, 02:12 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
definitelly LM series
make search here for amps with paralleled LM3886 - you need them , because of increased current capability
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 25th November 2009, 02:54 PM   #3
Considering that LM series is powerful than the STK series, which series in LM i can opt for?
LM3886 or is there any better IC's which can produce 100w RMS?
Old 25th November 2009, 05:45 PM   #4
If you are after power, go for the STKs. They are available up to 200 W. Second option are TDA7293/TDA7294 with up to 100 W. The LM series cannot deliver more than ~60 W without bridging or paralleling several of them.
To determine the best subwoofer box design, you need to know the Thiele/Small parameters of the driver. With them you can determine the best box size and the most promising box or no-box type.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 26th November 2009, 12:37 PM   #5
How can i choose a subwoofer?
If the size of the subwoofer increases will the o/p increase? Eg: If i am using a 10" 100w subwoofer in place of 12" 100w subwoofer will it make a difference? If so will it be a good difference or a negotiable one?
How much ohms sub i have to select? I am planning to go for a 4 ohms one is that good or i have to opt for 2 ohm sub?
What should be the frequency of the sub which i am gonna choose?
I am planning to look for a one with 20Hz to 100 Hz... will it be OK or i have to opt for a lower frequency?
The most important question.... How can i decide a sub is good or not? is there any tests for that without connecting it to an amp? Most of the items available in INDIA are not genuine ones and i can find a lot china made woofers even for which certain vendors are charging it with exorbitant prices... So i want to know whether its good or not by doing some manual tests .....
Thanks In Advance,
Ela
Old 12th January 2010, 02:50 PM   #6
I m still stuck .... can anyone help?
Old 12th January 2010, 03:16 PM   #7
zeonrider's Avatar
Default Hi!
STK for Life!
Regards zeoN_Rider aka stoN_Kold
LMxxxx Thermal Simulation zenon Chip Amps 11 5th October 2006 02:05 PM
LMxxxx chip as a buffer inside feedback loop? 300_baud Chip Amps 3 12th November 2004 07:08 PM
+/-30v tranny too big for LMxxxx? Riku-78 Chip Amps 47 4th November 2004 01:23 AM
Page generated in 0.09121 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
