| Chip Amps Amplifiers based on integrated circuits |
dc 25v on spk out LM3886
#2 |
Are you getting 25vdc on the speaker output? if is that....Something is REALLY wrong.Do not connect any speakers ( you will fry speakers).can you post schematic.Did you follow instructions correctly?. Go over the entire amp again, This time take it slowly.
#3 |
How do you connect the ground? Is it a P2P wiring or PCB mount?
#4 |
May be your 3886's inverted input is floating from a bad solder joint or somthing else. So I would check the solderings first..
Best regards, Ozgur |
#5 |
my first project lm3886 is success,the second project having a problem
http://DogBreath.de (Mick Feuerbacher 2007) |
#6 |
With the voltmeter, is there the same amount of voltage inside the power caps?
If it is different, that can get to the output. This can also happen if one rail isn't hooked up. It can also happen if the chip is bad or worn out. |
#7 |
100_2251.jpgCASch.jpg 100_2271.jpg My first project LM3886,Successful and very good sound.(view the schematic) for my second project,getting 25v dc volt at pin 3.supply cap voltage at output.i ready replace the new lm3886 chip,but getting the same result.i will check again all the connection,maybe i am wrong.izit good to use the crocodile clip for supply (+V & -V)connections and GND connection for testing?correct me frm wrong.Thanks...........JESUS MY SAVIOR |
| Lm3886 | MJS | Chip Amps | 3 | 7th December 2006 12:09 AM |
| LM3886 Pin-7 | GarMan | Chip Amps | 1 | 13th April 2006 05:32 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 11:24 AM |
| Page generated in 0.10037 seconds (67.36% PHP - 32.64% MySQL) with 11 queries |
