| Chip Amps Amplifiers based on integrated circuits |
My plan is to build a dual mono amp using the great looking kit from Audiosector. This is a first time project and I just wanna make sure I got everything in place.
So a single torodial transformer of 300VA 2x22v will connect to the two amps, each amp serving one channel. I know I will have to get a control for volume and in/out connectors, but will i need anything else to make it work. I dont wanna get half way thru and find I gotta go find a small electrical part. As I understand it this should give me 60watts per channel is that right? |
#2 |
Banned
You do know about the rectifier and filter caps, don't you? AND proper earthing, on/off switch, case (earthed), AC lead and socket, input switching, earth loops, et al?
Frank |
#3 |
I havnt done one of these kits before and was just asking if there is any hardware I need to get before I start. or is the kit complete bar the transformer as far as a working amp goes.
#4 |
Basically complete, since Audiosector kits come with a rectifier board.
You'll also need some sort of signal input jacks, some speaker binding posts, a power inlet (either a cable and grommet, or an IEC socket) and the transformer. Also useful is the knowledge of how to wire up the inputs with correct grounding so your amp doesn't hum, and how to wire up and mount the transformer so it doesn't kill you. |
#5 |
Oh, also, LM4780 is a stereo chip - you either buy one board, and it supplies 2 x 60W (into 8 ohms) channels, or you buy two boards and set them up for bridged operation, in which case each board will give you 1 x 120W (into 8 ohms) channel.
#6 |
Thank you, I am reading a lot of posts about the construction. I am expecting some teething trouble but I see most answers are here somewhere.
Also good to hear I will have twice as much as I was expecting watts wise. Dont want it loud, but a nice sound would be nice. |
| LM4780 SS Pcb | pinkmouse | Chip Amps | 67 | 31st January 2011 12:35 PM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| MY LM4780 Amp | ziling | Chip Amps | 7 | 6th July 2007 06:46 PM |
| anybody tried a LM4780? | travis | Chip Amps | 162 | 23rd March 2005 09:14 PM |
| lm4780 | odysseybmx414 | Chip Amps | 2 | 22nd February 2005 07:13 AM |
| Page generated in 0.08126 seconds (75.14% PHP - 24.86% MySQL) with 10 queries |
