Old 26th May 2003, 06:39 PM   #21
The reason I asked if I should build using metal enclosure is I thought using metal would help in shielding and ground connection.
I thought the main ground wire should be connected to the case and ground/shield wire of the toroids. Each channel's ground (to positive speaker output) should also connect to the case ground. Isn't it correct?
BTW, I also tried 3300uF rather than 1000uF and the sound was horrid (harsh, mid-fi sound). I also try some techflex cover on my Cat-5 power cable and the sound got worse (less dynamics)
Old 26th May 2003, 08:52 PM   #22
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
You are correct about the shilding effect of a metallic case but probably the best solution is a non-metallic case lined with a thin sheet of copper.
The earthwire is attached to the case (or shield/heatsink) to 'drain away' the RFI. It is also attached to the power ground star via a 100 ohm resistor with a 0.22uf cap in parallel (values vary).
The loudspeaker returns are connected to the power ground star.
I'm not surprised. Damping cables is not a good idea.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Stupid transformer question I should know but don't Boomy Power Supplies 2 25th August 2007 09:14 PM
Custom Stainless steel speaker terminal plates amit uk Swap Meet 0 17th January 2007 03:45 PM
Where to find ceramic/Alu-oxide plates? Ultima Thule Parts 4 12th January 2006 12:06 PM
3886 Transformer wiring stupid question thermonuclear Chip Amps 2 16th September 2005 05:38 PM
Where can I find metal plates for amps, stands. etc.? 959Turbo Everything Else 1 24th January 2002 02:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
