Old 19th November 2009, 02:38 PM   #1
Default Heatsink for 4780
Im twiddling my thumbs waiting for my kit to arrive and running thru some case ideas. After a lot of looking around and getting some ideas I was hoping for advice n help on heatsinks.
I understand the 4780 kit runs pretty hot and I would rather over-do it than under. My q's...
Would a PC cpu heatsink and fan be upto doing the job or would the fan cause a problem?
I see a lot of people using a long heatsink as part of the case design.. Where can I get these from in the uk?
What is the best material to use copper or aluminium?
Old 19th November 2009, 03:28 PM   #2
lanchile's Avatar
A well designed amp will not need a fan! if you can get a big heatsink is better. Copper vs aluminum? Copper will dissipate more heat for sure but it is more money!.try to use speakers with high SPL that way you do not force too much your amp and runs a little cooler.You can always make your own heatsink from scratch (That is way this is called DIY lol)or just get one from an old amp.Also you can get a hefty broken amp ( for Heatsink) from ebay and get a nice heatsink you can even use the chassis and other comps. I have seen nice ones for $40 -80 Hafler (broken of course). Good luck
4780 troubles jimbo1968 Chip Amps 12 7th February 2010 10:34 PM
new 4780 amp. CECCO Chip Amps 1 12th May 2008 12:25 AM
My New 4780 Case kestrel200 Chip Amps 7 26th April 2005 03:18 AM
Help with my 4780 board? Kevin Haskins Chip Amps 3 20th September 2004 08:28 PM
problem with 4780 Faber Chip Amps 3 20th June 2004 09:58 PM
Page generated in 0.07529 seconds (73.72% PHP - 26.28% MySQL) with 10 queries
