| Chip Amps Amplifiers based on integrated circuits |
#41 |
The comparison is not fair, TDA2030 is an ancient IC now, LM1875 seems to be much newer.
I use to feel like the small child in The Emperor's New Clothes tale
#42 |
so true Eva, they are not even the same power rating, as ive said before, the tda2050 is a much better match to the lm1875. both around the 30watt mark the tda2050 will take 50v (+/-25v) the lm1875 60volts (+/-30v) but the tda will provide a touch more current, but with a few % more thd noise.
steve. |
#43 | |
A particurlarly interesting kit for beginners is the Quasar Kit #50, sometimes named QK50 or K50. This features the LM1875 and there is a matching power supply for it too. The resistor values for K50 are off kilter slightly and should probably be more like 122k with 2.7k for the gain divider and 100k with 2.2k for the input divider. The NFB cap (22uF) could use a 22nF polyester cap added to it (paralleled, term is "bypass cap"), and the input cap could probably use a 10nF paralleled to it. Or some people replace the stock caps with Panasonic FC/FM. The resulting amplifier is still extremely inexpensive and its capable of high fidelity. Here's an example of efficient speakers to use with lower power amplifiers: Parts-Express.com:*Tang Band W6-789E 6-1/2" Woofer | BLACK09 Tang Band W6-789E woofer 6-1/2 woofer poly cone woofer midbass tangband tb speakers I had begged them to restock that model because its useful as a coaxial, or midrange or a woofer. Its also 92db efficient. With an efficient and high fidelity speaker, an LM1875 or even a TDA2030 can make significant levels of nice clear output. Have fun! |
| BPA possible with TDA2030? | mateo88 | Chip Amps | 11 | 19th February 2012 05:44 PM |
| is LM1875 replacement for TDA2030(A) | drmr_bg | Chip Amps | 10 | 16th January 2012 10:55 PM |
| 200w Tda2030 Amp - Need Help ! | Mx | Chip Amps | 12 | 20th June 2007 02:39 PM |
| tda2030 or opa544 or lm in the same box | Kirll | Chip Amps | 0 | 28th January 2005 12:46 PM |
| tda2030 bridge | vlljpior | Chip Amps | 0 | 10th August 2004 07:23 PM |
| Page generated in 0.07680 seconds (70.68% PHP - 29.32% MySQL) with 11 queries |
