Old 17th November 2009, 01:16 PM   #1
Default Best and most powerful DIY Chip
Which one is best and most power full with best quality sound. LM3875 , LM38886 or tda7294. Is TDA7294 is better than LM3886. Or there is any other tda or stk chip which is most better .
Old 17th November 2009, 01:50 PM   #2
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
The most powerfull chipamp is TDA7293, you can feed it with until +/-50v and have 100W RMS into 8R load. Also they can connect both parallel and bridge very easily then with like a BPA300 configuration you can get ~500W with just 6 x TDA7293!
However, if youre asking for the "best sounding"chipamp" then my vote would go for LM3875 (56W into 8R max.)..
Best regards,
Ozgur
Old 17th November 2009, 02:19 PM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I have been (ab)using single TDA7294 (not parallel) with +/-42V on a 4 ohm bass horn for 10 years with just 2 failures. It's probably the most powerful single chip solution in that size.
I use to feel like the small child in The Emperor's New Clothes tale
Old 17th November 2009, 02:23 PM   #4
star882 is offline star882  United States
star882's Avatar
The TAS5630 can output 600W into 2 ohms.
Digital Amplifier Solutions - Analog-Input Class-D Speaker Amplifiers - TAS5630 - TI.com
If you're looking at more than that, you'll be best off with a discrete design.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 17th November 2009, 07:36 PM   #5
redrabbit's Avatar
Apex PA-03 power opamp.
...supposedly up to 1000 watts per device.
I may try it, I have 3 pieces.
I may try it with an SMPS to keep it smallish. (??)
Why build one ?
I
don't
quite
understand
either.
=RR=
Old 17th November 2009, 08:59 PM   #6
lanchile's Avatar
I second it too! if He looks for better sound, LM3875 is the way!
Old 17th November 2009, 09:30 PM   #7
jackinnj's Avatar
But look at the distortion vs power chart on the TDA7293 -- with a bridged LM4780 you can get 115W at 1/10th the distortion.
Old 18th November 2009, 07:25 AM   #8
Dxvideo's Avatar
Sure... But there are two options; a powerfull amplifier with an acceptable THD value or a hi-fi amplifier with a lower power. And just one 7293 can give power as much as two 4780s...
By the way, I have a 4780 amplifier in my drawer.. And believe me, its not comparable with LM3875!
Best regards,
Ozgur
Old 18th November 2009, 08:29 AM   #9
GK is offline GK  Australia
Apex PA03.
The last time I ordered a pair of puny to-3 style Apex devices for a work project (since put on hold, so I've managed to avoid telling the boss that I blew one up till now) they cost over $440 AUD each. I shudder to think of what they would charge for one of these:
http://apex.cirrus.com/en/pubs/appNote/Apex_AN06U_C.pdf
Old 18th November 2009, 08:35 AM   #10
U mean lm3875 is better in sound quality than lm4780
powerful Chip - audio digital amplifier olzon Chip Amps 1 14th November 2008 08:25 PM
Powerful bass syl Solid State 13 2nd July 2007 11:29 PM
simple but powerful sr2002 Chip Amps 19 1st August 2005 07:20 PM
Any chip-amps more powerful than LM3875? DeonC Chip Amps 12 9th February 2004 02:46 PM
Page generated in 0.10613 seconds (76.43% PHP - 23.57% MySQL) with 10 queries
