| Chip Amps Amplifiers based on integrated circuits |
#11 |
ok and for subwoofer 4780 bridge or tda7294 better
#12 |
Electrons are yellow and more is better!
I'll suspect Dxvideo haven't implemented the LM4780 well enough since this IC is two LM3886 chips inside. This LM4780 amp sounds quite good.
/Per-Anders (my first name) or P-A as my friends call me |
#13 | |
If its 8R your idea is correct, But if its 4R then you must use them in parallel configuration. However in other case LM3875 is a better chipamp (not for the subwoofers).. By the way, Dear Parenders, have you ever compared a 4780 with a 3875 with simultaneous listenning?
Best regards, Ozgur Last edited by Dxvideo; 18th November 2009 at 08:43 AM. |
#14 | |
#15 |
Absolutely what I meant.
I have a lot of comparing implementations with these two amps. And I decided that LM4780 (or 3886) have not enough musical performance as LM3875.
Best regards, Ozgur |
#16 |
I have not listened to much chipamps but I agree - 3875 is better. I certainly like it better then TDA or 3886 chipamps.
#17 |
The new LM3875 in an ROHS version has been out for a few months. I agree that the LM3875 is a nice amplifier chip. The LM4780 takes up only a bit more space and is a bit fussy about its skinny pins, but it's a real work-horse.
#18 | |
PA-03 =RR= |
#19 |
Price out some high power MOSFETs or IGBTs. There's a reason why they're the device of choice in most inverters.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#20 |
| powerful Chip - audio digital amplifier | olzon | Chip Amps | 1 | 14th November 2008 08:25 PM |
| Powerful bass | syl | Solid State | 13 | 2nd July 2007 11:29 PM |
| simple but powerful | sr2002 | Chip Amps | 19 | 1st August 2005 07:20 PM |
| Any chip-amps more powerful than LM3875? | DeonC | Chip Amps | 12 | 9th February 2004 02:46 PM |
| Page generated in 0.10880 seconds (78.20% PHP - 21.80% MySQL) with 10 queries |
