Old 17th November 2009, 07:08 AM   #1
Default Audiosector newb questions.... searched for hours
I am seriously considering purchasing a Audio Sector LM4780 kit, however the schematic posted on Peter Daniel's website is a little confusing. It shows bridged and stereo mode as the same circuit. Not really understanding how that can be. I am looking to get a 120 watts per channel using two LM4780 boards. One board bridged for the Left channel, one bridged for the right. They will be driving a pair of Cerwin Vega Ve12F speakers with 8ohm impedances. My preamp has balanced xlr and TRS outputs only.
Does anyone have pictures of completed configurations such as this, to get me on the right path. I have probably spent five hours reading through threads here, before registering to find out how the bridged mode is using a left and right channel input/output. Only the parallel schematic looks close, but that wouldn't give me the 120 watts per channel into 8 ohms that I need.
Any help is greatly appreciated.
Old 17th November 2009, 07:59 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
The pcb can be used bridged mono, or stereo You can even connect the two channels in parallel.
/Per-Anders (my first name) or P-A as my friends call me
Old 19th November 2009, 03:58 AM   #3
Thanks, I guess I will just buy the pcb and see if I can figure out the bridged wiring. I hope it comes with better schematics than the website.
Old 19th November 2009, 05:16 AM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You can see it better here: AudioSector-chip amp kits, dacs, chassis
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 19th December 2009, 09:14 AM   #5
Think I got the wiring now, the XLR provides the inverted signal and the outputs are tied together. Anyone have a recommendation for the voltage and wattage of the transformer? I am planning on using one rectifier board and one transformer driving both the bridged channels. (both boards in bridged mode)
Old 20th December 2009, 08:44 PM   #6
If you go to the Audiosector part of forum there are lots of links and info. Kit is nice, and Peter Daniels is awesome with his help.
Old 20th December 2009, 08:55 PM   #7
I would go with 400VA unit with voltage ranging approx 2 x 22 V AC.
www.audiosector.com
Old 20th December 2009, 11:31 PM   #8
Thank you sirs.
Basic questions for newb whitecrook Full Range 0 5th August 2008 09:30 PM
Newb Questions mpw01 Multi-Way 7 4th March 2008 03:35 PM
AudioSector LM4780 Dual-Mono - questions/build log gongzero Chip Amps 3 22nd October 2006 03:43 PM
I Got Newb Questions... Wyloch Multi-Way 1 28th February 2005 08:33 PM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 03:52 AM
Page generated in 0.08578 seconds (80.22% PHP - 19.78% MySQL) with 10 queries
