| Chip Amps Amplifiers based on integrated circuits |
#2 |
Can You describe all "X*" please (like V+, In, Out...).
Have 6 spare TDA2030a and also interested on simpe and good PCB |
#3 |
#4 |
My only comment is that your resistor values are too high all around. This could lead to noise and offset issues.
I would use 10K for the dividers, and about 22K input impedance (R1/R4 and R2, respectively), and 22K/1K for feedback loop (R5 and R3). Capacitor values of C1 and C2 will need revising to roughly 10x-20x their listed values to prevent LF cutoff. About the PCB, some tracks seem longer than they need to be - the one connecting C3 and R2, for instance, can be routed much shorter, and it's a pretty critical connection to minimise noise as it's a low-level signal. I would also not use a ground plane. Even if it's dedicated to low-level signal circuitry, the way you've done. A track is better to control where the currents are flowing. I would return R3 halfway between the input and power grounds, on the other side of the plane instead of the edge. This may require a little more tinkering. It will work just fine probably, but tweaking it slightly will help your S/N ratio. I would also look at a way to get a small film cap in || with the output cap. Actually, I would prefer you use a split supply as that eliminates the output cap and the R1/R4/C3 circus. However, that's your call. |
#5 |
PlzCan u give me any link to get best and perfect error free pcb layout or schematic.
| tda2030a Heatsink | hernanstafe | Chip Amps | 10 | 17th December 2007 01:47 PM |
| TDA2030A Power Amplifier | ali_moinuddin | Vendor's Bazaar | 1 | 24th September 2007 10:56 AM |
| output stage of tda2030a | Hentai | Chip Amps | 0 | 18th May 2007 08:56 AM |
| Hybrid amp: ECH83 + TDA2030A | Cursor | Tubes / Valves | 2 | 15th April 2007 05:12 PM |
| Page generated in 0.09422 seconds (74.64% PHP - 25.36% MySQL) with 10 queries |
