Old 15th November 2009, 07:11 PM   #1
Default LM4765 / LM4766 Bridged
I was wanting build a LM4766 in BTL, but am finding it difficult to find a schematic for this. The diagrams in the datasheets are sparse in detail to say the least. I know there are probably better chips out there, but wanted to make something p2p that would fit onto a single heatsink (i.e. not two LM3886's and the LM4780 is too delicate to work with - the whole LM4766 current capability issue)
I have subsequently found this diagram for a LM4765 and I am assuming that it is pin for pin the same as the LM4766. What would be the simplest mod to this diagram to convert the amp into a BTL.
Is it as simple as changing the inputs on one of the amps (pins 7 & 8) to make it into an inverting amplifier and then using the two outputs to drive a speaker (omitting ground of course).
Also if I was not wanting to use the mute and standby functions do I have to tie the pins down to ground or do I leave them not connected.
All help appreciated.
[IMG]Click the image to open in full size.[/IMG]
Old 15th November 2009, 07:25 PM   #2
when you convert one chipamp to inverting, the gain of that chipamp changes and similarly the input impedance changes. This further alters the RC time constants affecting the frequency response.
Far better to generate a dual polarity signal outside the chipamps and keep the chipamps either both inverting or both non-inverting.
There are lots of threads covering this topic.
regards Andrew T.
Bridged LM4766 resistor wattages ballsingtripp Chip Amps 18 12th March 2009 08:22 AM
Lm4765 Pcb pinkmouse Chip Amps 13 30th January 2009 05:40 PM
Which pcb is better (LM4766) linket Chip Amps 5 8th November 2005 11:00 AM
Why not use LM4766?and... Richard.C Chip Amps 5 24th August 2004 09:13 PM
PCB for LM4765? Eccu Solid State 0 17th May 2002 08:26 AM
Page generated in 0.07616 seconds (72.57% PHP - 27.43% MySQL) with 10 queries
