| Chip Amps Amplifiers based on integrated circuits |
I have made my first pcb for lm3886 chipamp. When I add supply it works because I can hear a little noise from the speaker and when I touch on the input it reacts, but after a few seconds it suddenly shut off. Anyone have an idea of what the problem could be? I have attached my pcb-layout. Thank you, Simon H.A. |
#2 |
Sounds like its getting hot
#3 |
It's not hot at all. I have mounted it to an oversized heat sink and if I touch the chip it's cold.
Regards, Simon H.A. |
#4 |
HF oscillations.
#5 |
Is there a way I can test if it's HF oscillations? I don't hear any whizzing noice or so when it plays music.
Edit: I checked with my oscilloscope to the output, and I see no oscillations at all. Last edited by Cyberzim; 14th November 2009 at 07:37 PM. |
#6 |
Audio Engineer
hi, What are your power rails as you may not be drawing enough current from the mute pin to keep the amplifer out of mute.
Data sheet indicates you need RM = (|VEE| − 2.6V)/I8 where I8 >= 0.5 mA. Regards, Andrew |
#7 |
here is the output when playing music.
It seems like when having no load it can work for much longer time before it shut down. My powersupply is about +/- 25V. |
#8 |
I will try change the resistor for the mute to 2K7, then I have at least 8mA of current.
#9 |
Didn't work
#10 |
Okay, I've discovered that if I connect the gnd from the supply to the speaker instead of the gnd from my amplifierboard It works until it starts clipping.
Edit: I also discovered that the voltage from gnd -> "+" on my board measures 48V and from gnd -> "-" measures 0volt. How can that be true? Last edited by Cyberzim; 14th November 2009 at 08:48 PM. |
| Yey - LM3886 works like a charm | Atilla | Chip Amps | 10 | 30th January 2009 05:46 PM |
| ML #23 shuts itself off after 5 seconds. | Howard Lan | Power Supplies | 5 | 8th December 2007 08:17 AM |
| My LM3886 GainClone almost works! | Big Pete | Chip Amps | 3 | 9th August 2005 08:11 PM |
| My first GC(lm3886) +fire works+ please help | rs1026 | Chip Amps | 5 | 6th November 2004 05:49 PM |
| Anyone for seconds?????? | Dannyball | Multi-Way | 10 | 21st June 2004 06:36 PM |
| Page generated in 0.10464 seconds (81.41% PHP - 18.59% MySQL) with 11 queries |
