| Chip Amps Amplifiers based on integrated circuits |
#11 | |
just another
I'd check for solder bridges between the negative rail and the Grnd lines (close to the chip they seem pretty close together. Tony. |
#12 |
There are no short cuts between gnd and negative supply.
Maybe it's the chip that there someting wrong with? I took it from an old amplifier my brother found at his apartment at the garbage. It was from an old PA speakerbox. Regards, Simon H.A. |
#13 | |
The 1uF cap looks like Cin, but where is Rin, the resistor connect the +ve input to ground? Did you measure the DC voltage at the output pin? |
#14 |
Please read LM3886 datasheet Fig1 to see the +ve input arrangement. Cin should be connected to the "input". If you don't use a pot, Rin may be replaced by a fixed resistor. I hope this will solve your problem.
#15 |
I'm a bit unsure of what you mean, could you maybe draw it for me?
And the output measures -5.5V with ground as reference. Regards, Simon H.A. |
#16 |
Sure...
#17 |
Okay I give up.
It can only be the chip that there are something wrong with since I just took it from an old PA box. Thanks for all your help everybody. I will now wait for my TPA3122's that will arrive tomorrow and start building a class-d amp. Regards, Simon H.A. |
#19 |
Wow thanks!
Now it finally works. Regards, Simon H.A. |
| Yey - LM3886 works like a charm | Atilla | Chip Amps | 10 | 30th January 2009 04:46 PM |
| ML #23 shuts itself off after 5 seconds. | Howard Lan | Power Supplies | 5 | 8th December 2007 07:17 AM |
| My LM3886 GainClone almost works! | Big Pete | Chip Amps | 3 | 9th August 2005 07:11 PM |
| My first GC(lm3886) +fire works+ please help | rs1026 | Chip Amps | 5 | 6th November 2004 04:49 PM |
| Anyone for seconds?????? | Dannyball | Multi-Way | 10 | 21st June 2004 05:36 PM |
| Page generated in 0.09533 seconds (77.95% PHP - 22.05% MySQL) with 11 queries |
