Old 12th November 2009, 02:10 PM   #1
Default chip amp with 12v DC AND 240v AC power supplies?
Hi guys.
I'm interested in building a chip amp (maybe Hypex ucd 400) which has the capability to run from 12volt DC power (lead acid batteries) and also from 240volt Ac (uk mains). While maintaining high efficiency operation and safety.
Is it possible for a semi beginner? How would you go about it?
Old 12th November 2009, 03:52 PM   #2
ratza is offline ratza  Romania
ratza's Avatar
Hi. I would make a normal amplifier with 240/12V transformer and then add a connector after the diode bridge to allow connection at e.g. the car's battery. A relay can be added to decouple the battery if the amp is powered from the mains.
Any solution is a compromise.
Old 12th November 2009, 09:53 PM   #3
Pentode is offline Pentode  United Kingdom
Here's the UCD400 pdf data sheet and you wanna run it of 12Volts..... gee I've missed the boat, this beast can eat 400W with a 4 ohm load!
Dave
Old 12th November 2009, 10:17 PM   #4
Iain McNeill's Avatar
2 problems, the Hypex modules run off bipolar supplies +ve & -ve and the minimum voltage is ±45V. I think you have to go Tripath (T-amp) for 12V single supply.
Old 13th November 2009, 12:15 AM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
A SMPS is required in order to get enough internal supply voltage for decent power output with 12V input.
I use to feel like the small child in The Emperor's New Clothes tale
Old 13th November 2009, 02:53 AM   #6
star882 is offline star882  United States
star882's Avatar
Use a power supply with an output voltage of 14.4v, then use a boost converter or push pull converter to increase it to what you want. It will also work as a charger.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 13th November 2009, 04:28 PM   #7
Ok, So I guessed this would be a little complex. Most of that went over my head.
So does that mean that the Hypex modules are not suitable for 12v dc operation without....
is that the same as an SMPS? Or is an SMPS just a type MOSFET?
I'm sorry that I only have a rudimentary understanding of this stuff. I just need to know if if it is possible (hypex or tripath)without losing loads of efficiency on the 12v side. If it is possible then I will have a reason to sit down and learn about it in depth. Thanks everyone for helping.
Old 13th November 2009, 04:38 PM   #8
If you want it to work off a single 12V supply you need to use the Tripath amps.
The hypex amps will require a Switched Mode Power Supply to step up the +12V to +45V and also invert it to -45V.
I don't know of any SMPS that can accept 12VDC to 240AC and output ±45V
Old 13th November 2009, 04:41 PM   #9
see this thread here:
Sure Electronics New Tripath Board tc2000+tp2050
but you won't get the full 100W per from a 12V supply. More like 18W into 4ohms and 9W into 8ohm.
Old 13th November 2009, 08:07 PM   #10
Eva's Avatar
Take a look at TDA1560 and TDA1562:
http://www.nxp.com/acrobat_download/...TDA1560Q_4.pdf
http://www.nxp.com/acrobat_download/...2Q_ST_SD_2.pdf
And I found this too while I was looking if it was still available:
http://cgi.ebay.es/70W-high-efficien...mZ250343501225
Simple method for 240V from 240V line eeyore Tubes / Valves 10 14th June 2007 11:42 PM
Bel Canto power modification to 240v ronenash Class D 3 24th May 2007 03:20 PM
power conversion US to UK [110v to 240v] make Power Supplies 2 12th February 2007 08:53 AM
Power Supply schematics for Thorens 240V AC Motor deduikertjes Analogue Source 1 21st December 2005 12:11 PM
240v power regulator HELP!! GazzaFloyd Everything Else 5 24th June 2004 06:17 AM
Page generated in 0.11283 seconds (80.30% PHP - 19.70% MySQL) with 10 queries
