| Chip Amps Amplifiers based on integrated circuits |
#11 |
The whole question is moot as it's definitely not a chipamp you want to do this ... you want a class-D amp like a Tripath based one.
It also has the benefit of sounding much better
#12 |
Each TDA1562 with 12V supply produces 3 to 4 times more power output than any Tripath with the same 12V supply. TDA1562 includes a voltage doubler and puts 24V to the speakers.
I love class D but with such a low supply voltage and no SMPS it's not a good deal at all.
I use to feel like the small child in The Emperor's New Clothes tale
#13 | |
Thanks everyone.
I apologize for my ignorance I thought classD and Tripath were all chip amps. I wish those tripaths and the TDA1562 had a bit more grunt (power). The TDA1462 looks like it could be just enough to run my tweeters but I'm also looking for power amps for 2channel 300w at 8ohm. I'd be a happy boy if I could half the number of amps i needed (by having amps which and run from mains and 12volt/24volt.) while maintaining efficiency and sound quality. So whats the drawback with using an SMPS? If I was to run off 24v would that help reduce power wastage? Quote:
#14 |
Actually it's pretty easy to make or hack a SMPS that outputs -+45V from 12Vdc and 240Vac. You just need to 2 SMPS's.
One that outputs 12Vdc from 115/240Vac (possibly a charger) and one that outputs +-45V from a 12Vdc supply. I'm just curious why you think you need that high power output since it seems like you wish to make a mobile solution. An amp with a -+45V supply would suck a standard 55Ah car battery dry in about 15 minutes at maximum volume into 4 Ohms speakers, so that's a short party. Last edited by Saturnus; 14th November 2009 at 01:03 PM. |
#15 | ||
big smiles. So then I can build a hypex amp with 2 SMPS and chose between them. What would the circuit/switch which would allow me to switch between the supplies have to be? Quote:
#16 |
OOps I didn't read your post properly. You're saying that I should put in a power supply which does the 12vdc to +- 45vdc and then for the 240v operation hook up a second power supply to supply the first to with its 12vdc thats brilliant.
Then all I would need to do is have a switch which interrupts one of the wires from the 240-12v supply when in 12v mode. Thanks everyone I'll start looking for suitable components. |
#17 |
But you are going to have trouble finding a ready made 12V to +/-45V SMPS and learning curve may be quite long if you want to DIY it... That's why I suggested TDA1562.
#18 | |
I think the easy solution for you is to buy standard car amps instead unless you have a lot of experience in building SMPS's. Last edited by Saturnus; 14th November 2009 at 08:17 PM. |
#19 | ||
Thanks Everyone for your help.
#20 |
Check out the system on the right here
The Burning Amp Festival- an Audio Happening The Burning Amp Festival- an Audio Happening If I remember correctly, Kstlfido had these speakers playing all weekend on a solar panel & car batteries at Burning Man. ...and I'm sure you've read this thread The Boominator - another stab at the ultimate party machine
| Simple method for 240V from 240V line | eeyore | Tubes / Valves | 10 | 14th June 2007 10:42 PM |
| Bel Canto power modification to 240v | ronenash | Class D | 3 | 24th May 2007 02:20 PM |
| power conversion US to UK [110v to 240v] | make | Power Supplies | 2 | 12th February 2007 07:53 AM |
| Power Supply schematics for Thorens 240V AC Motor | deduikertjes | Analogue Source | 1 | 21st December 2005 11:11 AM |
| 240v power regulator HELP!! | GazzaFloyd | Everything Else | 5 | 24th June 2004 05:17 AM |
| Page generated in 0.11040 seconds (80.37% PHP - 19.63% MySQL) with 10 queries |
