| Chip Amps Amplifiers based on integrated circuits |
i want to make cmoy amp n i have all the part list except OPA 2132PA ic because its hard to find in my place .. can i just use Lm 386 ic on cmoy amp shematic?
#2 |
You could use a LM386 for your headphone amp , of cource you know it has different pin designations so it won"t match up with the schematic and you will have to modify the circuit to use the LM386 .... the OPA2134 is a dual fet opamp were the LM386 is a single low voltage power amp so there will have to be quite a change in the circuit design andf you will need 2 LM386 for one OPA2134 .... the circuit will also be much more noisy with the LM386 so sound quality will suffer ....
if you want to stick to the original Schematic you can use more commonly available opamps , the TL072 will work so should the ne5532 .... Cheers |
#3 |
The answer is no... the LM386 is not an opamp as such.
#4 |
thanks for the help.. if i get TL072 can i simply follow the cmoy shematic instruction? or do i need adjustment such as capasitor, resistor n etc...? sorry iam beginer on this..
#5 |
thank you
#6 |
If you use the TL072 you won"t have to change the circuit at all...
#7 |
thanks Minion!! you are realy2 helped me...
| Someone help: SE shematic with GK71? | bezobraznia | Tubes / Valves | 30 | 24th April 2011 01:17 AM |
| Shematic for Pioneer pd9700 | petronius | Digital Source | 0 | 16th February 2007 10:56 PM |
| Classe DAC-1. shematic | vadimgal | Digital Source | 3 | 21st September 2006 07:53 PM |
| NEC A10 shematic | vd-two | Solid State | 0 | 5th April 2005 11:08 AM |
| shematic of vincent cd s1.1 | alchemy | Digital Source | 5 | 29th October 2004 02:31 PM |
| Page generated in 0.09225 seconds (70.85% PHP - 29.15% MySQL) with 10 queries |
