| Chip Amps Amplifiers based on integrated circuits |
#11 | |
#12 |
Your torroid voltage is too high. The ebay ad calls for 28 volts DC which needs 20 volts AC although 22 volt AC would probably work. How big are your heat sinks and did you use Artic Silver or something similar? As others have pointed out you must have low DC offset. If you use your own bridge rectifier and a regulator to drop the voltage your torroid will be fine.
Good luck, Ted Last edited by ted4412wilt; 11th November 2009 at 02:06 AM. |
#13 | |
Voltage: AC 28V-0-28V 5.5A My transformer outputs AC 25-0-25 and 420VA = 8.4A, tons of spare current on the amplifier side. |
#14 |
I could see only 2 To220 power diodes..and a small bridge rectifier (3 amp) probably for the preamp IC....
SivanandBalan |
#15 |
My mistake. It does call for 28 v AC so I guess the builder does not know what he is talking about. Maybe he is using half wave rectifier which will give lower voltage and poor performance. If you use a bridge rectifier and voltage reglation this might work.
#16 | |
Magneto the Gravity Man
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#17 |
Temporarily, and until the amp is sorted out, put a 2200uF cap in-series with the speaker + wire.
That way, when you blow one of the DC rails fuses and not the other, the consequences of 40 volts DC offset will be blocked by that new cap. Output cap--its better than a speaker fire. |
#18 | |
SivanandBalan |
#19 |
Here's the LM3886 datasheet from National Semiconductor.
http://www.national.com/ds/LM/LM3886.pdf You will find the output cap on page 6. |
#20 | |
| Please check my PS pcb board layout for problems???? | marchewd | Tubes / Valves | 6 | 10th July 2008 06:47 PM |
| circuit board problems for AVT50H | xbox540 | Solid State | 0 | 24th August 2007 07:01 PM |
| look for LM3886 board | mackin | Chip Amps | 7 | 29th November 2006 08:07 AM |
| Upcoming LM3886 SMD board | JJJ | Chip Amps | 8 | 6th November 2004 10:02 AM |
| LM3886-problems | joensd | Solid State | 5 | 24th June 2002 07:43 PM |
| Page generated in 0.11631 seconds (88.60% PHP - 11.40% MySQL) with 10 queries |
