Old 10th November 2009, 10:36 PM   #1
netbug is offline netbug  United States
Default A question about the LM3886 (chipamp kit) and Gain…
I have recently added some 98db speakers to my system and have run into a hum issue. My tube preamp has a very minor hum that was not noticeable on my 85db speakers. I’d like to reduce the gain on the ChipAmp to 23 to see if it will help. Then I ran into the following post today…
Originally Posted by AndrewT View Post
look at the datasheet again.
At a gain of 10 (+20dB) the amp is just stable.
At a gain of 12 (+21.6dB) it is slightly improved, but the phase margin is still low.
At a gain of 20(+26dB) the phase margin is getting better.
At a gain of 30 (+29.5dB) the phase margin is ~80 to 85degrees.
Many listeners report that the 3886 sounds good when the gain is around 26 to 30 times. I suspect it's due to the improved phase margin avoiding overshoot on fast transients.
Has anyone run a non-inverting lm3886 at 23db gain? What happens to the sound? In what way is the sound “less good”?
Old 11th November 2009, 07:30 AM   #2
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Do you mean 23dB or x23 gain?
Anyway, I have tested a 3886 amplifier with 10K/680R feedback that makes x15,71 and appx. 23,9dB. I did not hear any difference from x21 configuration.
Best regards,
Ozgur
Old 11th November 2009, 07:32 AM   #3
ratza is offline ratza  Romania
ratza's Avatar
The gain on the chip will not help too much, try to remove the hum from the preamp. The problem with the phase margin is that the amp will have the tendency to oscillate when phase tends to decrease to 0 degrees.
Any solution is a compromise.
Old 11th November 2009, 03:21 PM   #4
I was referring to 23db. The kit originally had 22k/680 Rf/R3 on the feedback. I swapped out R3 for a 1k. According to the manual gain = 1+Rf/R3 so I'm now at 23db.
I can still hear the hum when I'm within a few feet of the speaker, but it is greatly reduced with the lower gain. You are right that the best solution is to get ride of the hum. I think it may be an a/c heater issue.
Old 11th November 2009, 03:24 PM   #5
Dxvideo's Avatar
No! 22/1 makes x23 gain (~27,5dB) and not 23dB. And this is a good value for NFB line.
Best regards,
Ozgur
Old 11th November 2009, 03:25 PM   #6
AndrewT is online now AndrewT  Scotland
gain was = 1+[22000/680]=+30.5dB
gain now = 1+[22000/1000]=+27.2dB
regards Andrew T.
Old 11th November 2009, 03:35 PM   #7
ratza's Avatar
What schematic did you use?
Old 11th November 2009, 07:14 PM   #8
I'm not sure the difference. I'm just going by what it says in http://chipamp.com/docs/lm3886-manual.pdf page 14
I'm a network engineer who's midlife crisis consists of wishing he was an electrical engineer.
It’s a 6j6 based kit that I stumbled upon. Looked interesting .
Euterpe preamp update - Skiing Ninja Community Forums
Old 11th November 2009, 08:10 PM   #9
Gopher is offline Gopher  United Kingdom
Netbug - for info:
Voltage gain (in decibels or dB) = 20 x log G
Where in this case G = 1 + (Rf/R3)
AndrewT's figures are correct
Old 12th November 2009, 07:33 AM   #10
Dxvideo's Avatar
Are you repented from being a network engineer? Why?
I wish I would be a network engineer! Is circumstances different in USA?
Best regards,
Ozgur
My new Chipamp.com LM3886 kit almost there... cjkpkg Chip Amps 3 25th September 2009 04:35 AM
ChipAMP LM3886 kit space-cake Swap Meet 1 22nd October 2008 09:43 PM
dc offset question (regarding LM3886 Chipamp kit) prospero21 Chip Amps 3 15th July 2008 12:19 PM
LM3886 PCB's or Where is ChipAmp? DJ4MC Chip Amps 6 3rd May 2008 03:34 AM
Chipamp lm3886 qns marcusdeming Chip Amps 31 15th February 2008 05:11 PM
Page generated in 0.31334 seconds (43.72% PHP - 56.28% MySQL) with 10 queries
