Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 6th November 2009, 07:59 PM   #1
jackinnj's Avatar
Default LM4780+ 2 Way Plus Servo
I am thinking that perhaps the GBW of the LM4780 will allow the elimination of a quad opamp, or perhaps just use 2 duals. I have some small 2-ways and want to biamp them so am going to have some boards made --
God zegene de vliegende Nederlandse man
Old 6th November 2009, 08:07 PM   #2
Electrons are yellow
peranders's Avatar
R13? not right
Aren't the DC servos a bit slow?
LT1014 too slow for audio, only 20 dB feedback. Only 0.2 V/us which is worse than µA741.
/Per-Anders (my first name) or P-A as my friends call me
BPA300 Group Buy Round 4, SMD-kit and DRV134 pcb. Not too late to sign up. Sign up HERE
Old 6th November 2009, 10:01 PM   #3
R13 and R14 should be 20.5k, not far off.
DC servos are supposed to be slow, or else they affect the audio.
What is the purpose of U1A, U1D, U2A and U2D? It looks like they're filters, but what for?
http://arresting-audio.com/
Old 6th November 2009, 10:31 PM   #4
jackinnj's Avatar
Originally Posted by peranders View Post
R13?
1) 20.5K/1K OK
2) I won't use the LT1014 --it's just the IC I clicked on MultiSim -- could be National LME49740.
3) The other opamps are high-pass/low pass a la Linkwitz-Riley.
I have drawn it without buffer, and just one filter opamp.
Old 7th November 2009, 06:23 PM   #5
gfiandy is offline gfiandy
Audio Engineer
gfiandy's Avatar
Hi, I spent quite alot of time working on using power opamps as filters. It is fraught with problems as the gain bandwith product is limited. The very large currents and voltages at the output lead to problems with parasitic feedback.
It takes a long time to get this type of circuit working well so unless you really need to save the cost I would recomend keeping the extra opamps it will work better and be much more predictable.
Do a carefull noise analysis of your servos. The 2.2M resistors will be generating alot of Johnson thermal noise, now theoretically the caps filter this off but I am not sure what will happen at the negative virtual earth input of the opamp and you have massive gain here and I think the potential for noise to get amplifed. However I am not sure on this.
Andrew
Old 7th November 2009, 08:19 PM   #6
jackinnj's Avatar
Thanks, Andrew, that's why I asked the question (s).
Old 8th November 2009, 12:28 PM   #7
jackinnj's Avatar
Here's a bode plot of the servo itself -- the response is down 56dB @100Hz if I've drawn everything correctly!
Old 8th November 2009, 01:35 PM   #8
peranders's Avatar
You must take into account temperature variations which contribute to the offset. The -3dB level should be in the area on 1-5 Hz.
You make also a mistake here. You must include the LM4780 (or an opamp) also. The LM4780 will make the response slower.
Old 8th November 2009, 07:00 PM   #9
jackinnj's Avatar
With an 8MHZ GBW virtual opamp as a surrogate for an LM4780, the f3 is 4.6Hz and the output of the servo itself is down ~30dB @100Hz.
Old 8th November 2009, 07:23 PM   #10
peranders's Avatar
Did you have the same circuit as with the one you have drawn? Did you connect the input signal to the surrogate opamp?
Thread Tools
DC servo in DAC galouche Digital Source 5 2nd August 2007 09:33 PM
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
IC for DC servo ? K-amps Solid State 23 15th June 2006 08:17 AM
Servo add-on PCB Nicks Chip Amps 3 21st February 2006 05:36 AM
DC servo uli Chip Amps 20 3rd December 2004 11:40 AM
Page generated in 0.09504604 seconds (83.18% PHP - 16.82% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
