| Chip Amps Amplifiers based on integrated circuits |
#11 | |
I'll breadboard it this week and run it through the network analyzer. |
#12 |
Jack,
I think you need to use the LM411 or LM412 for the servo. Low initial offset and low offset drift. Offset is also adjustable. Or the LM412, same low offset and low drift not adjustable. Look at the national datasheets - compare the spec to the LM4562. The non-Jfet type opamps have much more offset and offset drift with temperature, both of which you're trying to eliminate by using a servo. Self's book has a chapter on servos. Ken |
#13 |
Electrons are yellow and more is better!
I put in the values into LTSPice and the -3dB is at 0.015 Hz!! I did also include the control object and applied the signal at the normal input.
/Per-Anders (my first name) or P-A as my friends call me |
#14 | |
I wonder, also, whether to make the LM4780's inverting, and use the inverting servo. |
#15 | |
Ken |
#16 | |
#17 |
#19 |
Also, you can use a JFET like a PN4117 or 2N4117 for a low leakage clamp instead of diodes, like I've done with my servo design.
Tyler |
#20 |
Jack,
No need to invert the servo. Here's the schematic from Doug Self's book. I've tried it, it works. The values shown give unity gain at 1 Hz. The two grounds shown should be connected to signal ground. Ignore the op amp designation, just grabbed it quickly to make the schematic. Ken |
| DC servo in DAC | galouche | Digital Source | 5 | 2nd August 2007 10:33 PM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 01:37 PM |
| IC for DC servo ? | K-amps | Solid State | 23 | 15th June 2006 09:17 AM |
| Servo add-on PCB | Nicks | Chip Amps | 3 | 21st February 2006 06:36 AM |
| DC servo | uli | Chip Amps | 20 | 3rd December 2004 12:40 PM |
| Page generated in 0.13023 seconds (81.20% PHP - 18.80% MySQL) with 11 queries |
