| Chip Amps Amplifiers based on integrated circuits |
Me again
Just wanted to test a theory. I know I will get some bashing, but it is just a theory. AC voltage is 230v. After rectification it is 336v. If you halve that you get 163v. Now if you accept that a LM4702B is safe up to 200v or 100-0-100 and look at the circuit below....then the theory schematic below with two LM's in series....will it work as the 'apparent' voltage across each of the LM's is a 84-0-84 supply [IMG] [/IMG][IMG] [/IMG]I realise that it will not be isolated from mains, but is it possible. Wizard |
#2 |
Do you really have to ask...
And to elaborate, provided the opamps as you have drawn them (floating) current share equally (and have theoretically identical characteristics at power up) then yes they would "work" The instant you unbalance that in any way the voltage seen by each would alter and go outside the limits. I don't think it needs discussing further really
#3 |
The other problem is with the signal ground, for the top chip it is at it's '-Vee' while for the bottom chip it is at its '+Vcc'. No joy, I'm afraid!
jd
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#4 |
#5 |
The only answer to this is theoretical.
If the caps differed in value the charge times would be unequal at switch on and so the IC's would be destroyed. Tolerance of elecroylitics cap could be -/+ 20 to 50 % And as Janneman correctly says mentioning inputs etc all this is before you even begin to think of interfacing them to anything.You will never create anything useful from this.... just getting them to survive a switch on event would be remarkable. If you want to see what happens build it up from 741's on a 30 volt supply and have a play and a measure. |
| Hot LM4702 | Dxvideo | Chip Amps | 7 | 18th June 2007 11:12 AM |
| lm4702 | rapunzelelch | Chip Amps | 25 | 6th February 2007 08:13 AM |
| Possible LM4702 PCB Buy | dfdye | Group Buys | 51 | 26th June 2006 03:46 AM |
| About LM4702 | gooday | Chip Amps | 2 | 15th June 2006 07:06 AM |
| Page generated in 0.08087 seconds (75.29% PHP - 24.71% MySQL) with 10 queries |
