| Chip Amps Amplifiers based on integrated circuits |
Hi
I have scavenge through my parts bin and have found enough parts to build a point-to-point chip amp. I will be following Nick's 3886 layout but I have a quick question regarding the value of two resistors. Building a Gainclone chip amp with the LM3886 chip. Earlier this year I built a pair of Pedja Rodic's discrete 27vdc regulated power supplies. Nick suggests attaching a 18-22K resistor to the negative supply pin if using a 35-37v. What value should I change this resistor to if the DC supply is 27 volts? His diagram also displays a 47-100K resistor between the star ground and input. Is there a optimal value? Thanks |
#2 |
just another
I'm using 10K with 28v rails (simply copied what briangt used).. you basically need to ensure that pin 8 gets 5mA of current or the mute will still be functioning (to a degree). The higher the resistance value (above what will allow 5mA) the more muted the circuit will be...
I've attached a graph from the datasheet, there is more info (including a formula for calculating the correct resistance value) in the datasheet. Tony. |
#3 | |
| Squeezebox (SB3) modications at Decibel Dungeon | Nuuk | Digital Line Level | 0 | 7th December 2008 12:29 PM |
| Decibel Dungeon Gainclone | Puffin | Chip Amps | 66 | 8th December 2007 11:31 AM |
| Decibel Dungeon GC w/LM3875 | Nordic | Chip Amps | 25 | 11th October 2005 12:06 PM |
| New URL for Decibel Dungeon | Nuuk | Everything Else | 0 | 30th May 2005 08:15 PM |
| Impressions of Snubbered BrianGT 3886 vs Reg 3886 | moving_electron | Chip Amps | 1 | 23rd March 2005 07:51 AM |
| Page generated in 0.09580 seconds (63.23% PHP - 36.77% MySQL) with 11 queries |
