Old 5th November 2009, 04:39 PM   #1
Angry TDA2030/TDA2040 frying after 10 secs of use?
I built the tda2030 and tda2040 test circuits and I am just frying these chips right and left. Anyone come across this?
I am giving the tda2030 0V to 30V and the tda2040 -15V to 15V. So I am giving them a lot of juice, but they dont draw that much current. The power supply reads 700mAmps for the first and 1.7 Amps for the latter.
Old 6th November 2009, 12:07 AM   #2
Minion is offline Minion  Canada
What do you mean by frying ?? How big is your heatsink ??
Old 6th November 2009, 12:59 AM   #3
Did it Himself
richie00boy's Avatar
Sounds like they are oscillating.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 6th November 2009, 01:02 AM   #4
Send a message via AIM to DigitalJunkie
x2 on the oscillation.
They should draw very little current at 'idle'.Check the data sheet for specific numbers.
Old 6th November 2009, 02:35 AM   #5
sivan_and's Avatar
Send a message via Yahoo to sivan_and
short the input and measure the idle current should be 50 ma or less !!
SivanandBalan
Old 6th November 2009, 09:49 PM   #6
Puffin is online now Puffin  United Kingdom
I thought the max voltage for TDA2030 was + - 18v?
http://www.datasheetcatalog.org/data...onics/1458.pdf
Old 7th November 2009, 12:17 AM   #7
Did it Himself
Which is a bit above the voltage he was giving it so will be fine.
Old 7th November 2009, 12:27 AM   #8
+/-18,or 36V from a single-ended supply.
Old 10th November 2009, 04:04 AM   #9
danielwritesbac's Avatar
Do you have a TO220 size mica and a shoulder washer?
PSU using TDA2040 ? poynton Power Supplies 7 10th February 2012 04:48 PM
transformer question (dual secs same as centre tap) homertooties Power Supplies 0 11th June 2007 09:12 PM
TDA2040 Amp Fritzell Chip Amps 0 20th July 2004 04:31 PM
Did the TDA2040 pan out? KT Chip Amps 0 6th May 2004 05:47 PM
you guyz will be able to answer this in 2 secs surroundmatt Multi-Way 1 27th December 2003 07:24 PM
Page generated in 0.10900 seconds (72.56% PHP - 27.44% MySQL) with 10 queries
