Another GainKlone is alive and singing!
Old 23rd May 2003, 12:27 AM   #11
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
Good job!! The inside structure is very compact ,I like it
Old 23rd May 2003, 02:15 PM   #12
Panelhead is offline Panelhead
Default Polarity of Electrolytic
The drawing attached has the polarity reversed on one of the 1000 ufd filter caps.
Have you tried the inverting input topology.
George
Old 25th May 2003, 03:49 AM   #13
overmind is offline overmind  Singapore
overmind's Avatar
Default Re: Polarity of Electrolytic
Actually, the mounting hole of the IC was drilled in the centre which is not too good. This make the construction cramped with parts on one side, and the other sider with much space. The leads of the components were not trimmed. The construction of the amp circuit will look better if the above two points were done correctly.
George
I have yet to try the inverting configuration. I will try this and increase the gain to 21x and report back. However, I am quite busy for the coming week, thus this will take some time.
Thanks & Regards,
SW Yeo
Another GainKlone is alive and singing!Hide this!Advertise here!
JBl GTS600, amplifier wanted! Dead or Alive, Alive if it can be helped:) Paradise_Ice Swap Meet 11 10th June 2013 02:02 PM
Zen vs. GainKlone MikeW Pass Labs 26 19th June 2003 07:52 PM
Newbie GainKlone VoLCoM Chip Amps 12 18th April 2003 04:10 AM
Copyright ©1999-2017 diyAudio
