| Chip Amps Amplifiers based on integrated circuits |
I am a newbie and I need help. Let's start with the begining. I have my PC connect to an amplifier in my basement and and it is connect to in-wall speakers upstairs in my living room. The setup is ok except that I have to go downstairs to get the volume up or down and I would also like a little bit more power. So I had the idea to use one of those small TA2020 PCB amp as an in-wall amplifier and volume controller. I thought of cutting my speaker wire at one point and put the TA2020 board between my basement amp and my speakers and and putting it in the wall with only the potentiometer out trough a wall plate, just like a light dimmer. Does this makes sense. I saw some board having just one ground for the two input channels (like this one), does this mean I will have to plug the two black wires from my basement amp to this ground and and one red wire to left and one to right. Also I have to figure out how I will have it powered up with no apparent wire. Please help me! |
#2 |
It would be better to skip the basement amp entirely or replace it with a preamplifier/buffer.
A common ground for both channels is normal. You can connect the wires the way you intende or you can even use only one of the black wires. You can use a wall-wart or a laptop power supply upstairs for the TA2020. ~20W for each 8 Ohm speaker and ~30 W for each 4 Ohm speaker should do.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Thanks for the reply. Yes, I'm planning to replace the basement amp for a tube preamp and a USB DAC eventually (it's a step by step project...). For the power supply, do you think I should solder a connector to the board or just cut the power supply wire and solder them directly to the board. I also want to know, my speaker cables are pretty big and and the wire I will connect to the board's input will be tiny, is it a problem to solder big wire to tiny one.
Just to be sure I understand everything, could somebody make me a diagram of all the connection and solder I will have to do if I use this board: ![]() ![]() ![]() ![]() ![]() ![]() I told you I am a newbie, but I really want to learn. |
#4 |
| Samsung 1602VFD For CDROM Controller & Remote Volume Controller | slowgay | Swap Meet | 2 | 22nd November 2008 03:44 PM |
| need 5.1 Channel Audio Volume Controller | halod | Analog Line Level | 2 | 5th March 2008 01:37 AM |
| RS 40-987 In Wall Traf. Volume Control as preamp attenuator | ultrachrome | Parts | 8 | 8th February 2007 12:55 AM |
| Niles in-wall stereo volume control (L-pad) | orthoefer | Swap Meet | 1 | 9th May 2006 01:39 PM |
| Page generated in 0.39053 seconds (19.85% PHP - 80.15% MySQL) with 10 queries |
