Old 7th December 2009, 04:04 PM   #881
Banned
The AD797 is darker than the LT1028... so that's the one I'd blame. Try OPA1612 (no need for singles) buffered by LT1028CS8.
Old 7th December 2009, 04:13 PM   #882
I'm not going back to dual chips
well sound is nice really, the AD797B alone had hot trebles...now the 1028 tempers them down, but I do think that the ACN8 sounded better than CS8...maybe it's just in my head, time will tell.
Old 7th December 2009, 04:16 PM   #883
Banned
Why, oh why??
You've got one dual opamp per each channel in your card, that is, no L/R crosstalk is involved. You won't lose anything.
No, it doesn't sound any better at all. I can compare them with the push of a button. And the DAC with the CS8 (powered with less than half the total V) sounds slightly better
Old 7th December 2009, 04:22 PM   #884
well, the SS is just wider w/ single chips...there's more stuff happening in the center, it's been dead obvious each time I've rolled dual <> single
it's also been dead obvious that all the discrete chips as final buffer give a slight stereo imbalance on my card..maybe due to the low voltage? they are said to require at least ±12V and I feed them a bare ±8.8V.
anyway! the 1028CS8 final buffer increases the bass response but distorts the trebles..don't really like it, I will take them off in a minute. I might just need 6*AD797BN, or maybe an OPA1611/LT1677 final buffer
Old 7th December 2009, 04:26 PM   #885
Banned
You're talking of the dual opamp that treats both channels, not of the duals that treat one channel each, I guess...
The LT1028 per se doesn't distort any trebles, really... I guess it might oscillate in your card.
Old 7th December 2009, 04:48 PM   #886
well, it seems that many ppl also agree that 2*singles are better...even on the OPA1612 they emphasise that the separation is better handled. Clearly, it gives more width to the center channel on headphones(better phase control?)
indeed the 1028 doesn't appear to be a drop-in replacement...but Slash47 said the same for the 797B, he told me it's oscillate like mad on my soundcard...it wasn't the case, there's no hard rule in op-amp rolling apparently
Old 7th December 2009, 06:56 PM   #887
Banned
You keep not understanding... Those two dual opamps in between DAC chip and output buffer [which is supposed to be a dual opamp, funnily enough] are each of them only in one audio channel's signal path. Two channels of a dual opamp are in the left channel's signal path; and two channels of the other dual opamp are in the right channel's signal path.
Therefore, for that stage, you have no reason to worry about stereo crosstalk, phase problems, or anything like that... so a dual version of a given opamp (e.g. OPA1612) will be in no way a compromise as opposed to two singles on Browndog.
Sure, if you want to complicate your life just because you refuse any dual opamp by an uninformed prejudice, you're free to do so...
Whereas, regarding the dual opamp that buffers your card's line out... well, there it makes sense to use an adapter with two singles, because the two channels of the dual chip would be used to buffer the L and R stereo channels respectively.
Old 7th December 2009, 07:37 PM   #888
Default Best Bass?
OK guys, which is the best op-amp for bass reproduction, I want tight and fast not rounded and full, if you understand. Its for an active filter hence bass reproduction is the main priority.
RC
Old 7th December 2009, 08:06 PM   #889
Originally Posted by Andrea: View Post
You keep not understanding...[..]
I am well aware of what you're saying...yet, I get much wider center channel w/ singles as DAC LPF...there's obviously much to be gained by processing each polarity on its own.
browndog says : Single-to-dual Op-AMP Adapter - DIP version (p/n 021001)
superior electrical and thermal isolation between channels vs. integrated dual op-amp
Precision Amplifier - Wide Bandwidth - OPA1612 - TI.com
The dual version features completely independent circuitry for lowest crosstalk and freedom from interactions between channels
dual chips are more than likely made of compromises....an IC op-amp is already damn small, so let's not ask for even smaller.
when reading the old AD797BN datasheet, they clearly explain that there's all kind of protections and so on built in...maybe there's a very good reason where there's no AD799
used as what? final buffer? I/V? LPF? at what voltage? which ones did you try already?
Old 7th December 2009, 09:46 PM   #890
oh yes! so much better w/o a final buffer, pure untouched AD797B goodness
-: Best audio OpAmps :- audioPT Parts 62 9th April 2013 11:44 AM
The Best Sounding DUAL opamps mudihan Chip Amps 214 1st May 2011 05:09 PM
best sounding Tx for sub 10watt class A audio amp? mondogenerator Solid State 2 2nd October 2009 05:21 AM
Help the Idiot: Simple, Great-Sounding Integrated Amp Designs SRMcGee Tubes / Valves 7 15th September 2005 06:43 PM
Copyright ©1999-2013 diyAudio
