| Chip Amps Amplifiers based on integrated circuits |
#1911 |
sorry ......
the dac is pcm 64 (denon dcd 3520) and not pcm 63 the question is same . thanks luigi |
#1912 |
I replaced the NE5532 with LME49720HA, the sound has improved in many ways.
What OPAMP s most highly recommended to try? I have: LT1358, LT1364, LME49720NA, OPA2137P, LT1057 |
#1913 |
That is a great op amp, I have tried it and use it in a home made pre. The Burr-Brown OPA2134 is one that is at the top of my list. But often, it is more of how the op amp integrates into the circuit that matters rather than how good the op amp itself is. But op amp rolling is fun. Also tried the OPA2604, but not had good results with it.
Good luck. |
#1914 | |
Hi Greeg thanks for your answer please but if use step-dawn transformer 4:1
2500 ohm / 600 ohm after the pcm56p can good matched dac/imput preamplifier with low impedence ? how you think ? thanks luigi Quote:
#1915 |
Foxye,
The LME49720HA (metal can) is the best opamp of the group you listed! Be sure to use a good regulator though and run the device at 15-19VDC rails...with a clip-on heatsink on the device. Do not use any plastic package devices. I just modified a D/A preamp last week (that I designed many years ago at National-now TI) by replacing all the plastic DIPs with metal cans. Several engineers who heard it were surprised that the same die in a metal can package could sound that different! (I actually did the same demo for Bob Pease during my first stint at National and he was shocked that he could hear the difference. Wish he was still with us!) The only plastic opamp I would play with right now is the LME49990. 0.9nV of noise! Of course my favorite opamp is still the CFB LME49713HA...but since I did specify that part I am a bit biased! It is a Current Feedback Opamp though and requires a few special considerations when using it, like a 1.2k to 1.5k feedback resistor.Best National...I mean TI regards, Audioman54 |
#1916 |
Audioman
A lot of the so-called evidence for the sonic qualities of different op-amps comes from anecdotal sources or poorly designed comparisons. I think your example of swapping plastic case for metal can versions of the same op-amp comes into that category I'm afraid because it relies on your memory of what the DAC sounded like before you made the swap, and that's not 100% reliable. Are you aware of a properly designed and conducted double blind test where the basic circuit remains the same and only the op-amp is different e.g. two identical DACs using different op-amps switched blind while playing music in a reference system. Did National carried out double-blind tests like this to evaluate their audio op-amps when you were there? If so, were any statistically significant differences between sonic qualities of the different op-amps tested found? Last edited by Gopher; 15th April 2012 at 07:08 AM. |
#1917 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#1918 |
Thermal? Selection?
#1919 |
I think abraxalito may be talking about mechanical stresses in the op-amp die being different in the two types of package. I may be wrong though.
#1920 |
Yeah - you are
My notion is that the metal can acts like a faraday cage, improving immunity to RF-induced effects.
| -: Best audio OpAmps :- | audioPT | Parts | 62 | 9th April 2013 11:44 AM |
| The Best Sounding DUAL opamps | mudihan | Chip Amps | 214 | 1st May 2011 05:09 PM |
| best sounding Tx for sub 10watt class A audio amp? | mondogenerator | Solid State | 2 | 2nd October 2009 05:21 AM |
| Help the Idiot: Simple, Great-Sounding Integrated Amp Designs | SRMcGee | Tubes / Valves | 7 | 15th September 2005 06:43 PM |
