| Chip Amps Amplifiers based on integrated circuits |
#1891 | |
I'll try a RC filter off 500R/220pF and change the servo op-amp to OPA2211 and report back. BTW, trying to stay a little on topic here, the LME49713 does sound excellent.
"If you don't like funerals don't kick sand in ninja's face." |
#1892 | |
I decided to keep with the NI theme and put in a LME49860 for the servo and I installed the input RC filters. Output offset is now ~9mV for both channels and the board sounds amazing. I can already tell I like it better than the LME49710/LME49600 amp I built. And about the previous mention of my not-so-great grounding method; the board is as silent as silent gets. No hum, hiss, noise whatsoever. Thanks for the help fellas.
#1893 |
#1894 | |
#1895 |
I am surprised annonymous1 that you are reporting offsets at this level. Something does not sound right here. Are you willing to post up your circuit?
#1896 |
I'm seriously amazed by how good OPA1641 sounds..I don't like OPA1611 or OPA827, but darn 1641 is unbelievable as PCM1793 LPF
#1897 |
I've tried this relatively new opamp from Analog Device
I got the samples from them and I had to make tiny pcboard to make them fit in my DAC since the opamps are mono my impression it is better than the plastic LM4562NA , more air, smooth and rich mid, wider sound and more open, I haven't compare it to the can LM4652HA, but right now I have this opamps in my MSB link III and LM4652HA in my highly modified Musical Fidelity A324 Anyone ever tried this opamps? I interest on your opinion thanks |
#1898 |
please, i have need the help for BB pcm56 P , I would like to connect this dac direcly a my premplifier without opamps ,
I have read data sheet and the pin 9 have volt output and pin 2 ground but How ? Thanks luigi |
#1899 |
Buongiorno Luigi,
Generally it's not good design practice to have a DAC directly drive cables of any length, or another separate stage- it will perform poorly, even if it's a voltage type output. Either select a very good sounding op-amp as a driver/follower, that will have low noise, wide bandwidth, high slew rate, low output Z, and low input current, or build a discrete design with FETs or bipolars- more difficult. The BB family of op-amps like OP27 and similar are really nice sounding, quietand you can run the supplies up to (+/-)18 or 20 volts, which gives lots of headroom. What is the preamp and what is the first device the signal hits when arriving at the pre-amp input? Input impedance? Nominal line level expected is -10dBv or +4dBM? ( home & garden vs professional audio levels) Some of the big recording consoles use video op-amps as buss drivers because of these qualities plus the ability to drive low Z such as 50 Ohms. Please send the data sheet for the DAC- that would help for further advice. Ciao, Gregg |
#1900 | |
thanks for your reply .
i give you more information : i have yamaha cdx 10000 with pcm56p but i would like to direcly the dac to input transformer of my preamplifier this is data sheet of pcm56p and my preamplifier is push pull transformer circuit imput transformer is 30k-30K i have connected pin 9 of dac to +plugs cable and 2 pin to - plugs cable the volume gain is good but the sound goes up and down as if there was anyone that lowers and raises the volume Quote:
| -: Best audio OpAmps :- | audioPT | Parts | 57 | 13th October 2011 02:47 AM |
| The Best Sounding DUAL opamps | mudihan | Chip Amps | 214 | 1st May 2011 06:09 PM |
| best sounding Tx for sub 10watt class A audio amp? | mondogenerator | Solid State | 2 | 2nd October 2009 06:21 AM |
| Help the Idiot: Simple, Great-Sounding Integrated Amp Designs | SRMcGee | Tubes / Valves | 7 | 15th September 2005 07:43 PM |
| Page generated in 0.16629 seconds (76.89% PHP - 23.11% MySQL) with 11 queries |
