Old 25th August 2010, 10:39 AM   #1871
panson_hk's Avatar
I recently build a pre-amp using OPA134 (single channel version of OPA2134). The opamp is non-inverting unit-gain stage followed by a volume pot. It is indeed a very good sounding opamp.
Old 25th August 2010, 10:51 AM   #1872
Joachim Gerhard's Avatar
What is your source impedance ?
Old 25th August 2010, 11:27 AM   #1873
panson_hk's Avatar
my source is a CD player. In the previous post, I mentioned the order reversely. The pot is followed by the opamp.
Old 25th August 2010, 12:31 PM   #1874
I was trying to understand why you decided to put a buffer in front of the pot.
Buffering the output of the pot makes sense.
regards Andrew T.
Old 25th August 2010, 12:36 PM   #1875
When you have configured the Opamp as a voltage folower you get less distortion in the treble when you use a resistor with the same value as the source impedance instead of the short between Pin2 and Pin6. I am also astouned that you use a pot BEHIND the buffer. That destroyes the nice low output impedance and a buffer does not make much noise so you win little in SN with the pot at the output.
Old 25th August 2010, 12:42 PM   #1876
YES!!!!
Some opamps behave so badly when output is fed back to -IN that the datasheet shows this extra resistor.
I have concluded that using this extra resistor cannot be any harm when any opamp is used in unity gain follower mode.
regards Andrew T.
Old 25th August 2010, 12:47 PM   #1877
i usually use something around 1kOhm.
Old 25th August 2010, 12:59 PM   #1878
panson_hk's Avatar
I already made a correction in #1873. The pot is before of the opamp in the signal path. You don't see that? Or there is delay due to the server?
Old 26th August 2010, 10:59 PM   #1879
panson_hk's Avatar
Is the the common-mode distortion in series-feedback configuration?
Old 27th August 2010, 02:53 AM   #1880
Yes.
-: Best audio OpAmps :- audioPT Parts 57 13th October 2011 01:47 AM
The Best Sounding DUAL opamps mudihan Chip Amps 214 1st May 2011 05:09 PM
best sounding Tx for sub 10watt class A audio amp? mondogenerator Solid State 2 2nd October 2009 05:21 AM
Help the Idiot: Simple, Great-Sounding Integrated Amp Designs SRMcGee Tubes / Valves 7 15th September 2005 06:43 PM
Page generated in 0.12800 seconds (73.75% PHP - 26.25% MySQL) with 11 queries
