| Chip Amps Amplifiers based on integrated circuits |
#1851 |
diyAudio Moderator Emeritus
Now we're speaking of oscillation in the mHz range. It could be that is the cause for you liking the sound as it is now !
BTW 30 secs is good but I suppose the PCB is (old school style) good quality. Most modern manufactured PCB material does not last long when soldering 2 or 3 times. Tracks peel off easily, that is why I warned you for possible damage. I reworked 3 "hong kong dac's" a few months ago and 1 sec with the soldering gun was enough to peel off the tracks. AFAIK there is not much wrong with solid caps. It is OSCON that, despite its good specs on paper, manages to screw up sound big time. Just like you I like the older Spitfire better as seen from the pics for modability ( if that's an english word ?!?). I never heard either of them.
It's only audio |
#1852 | ||
well yes it's entirely possible! But I always thought that oscillation would add some "zing" to the trebles...like it's often the case on improperly implemented LM4562's...that nasty metallic treble color I cannot stand
![]() w/o the socket, the low end bass was dull and felt like not much was happening <50Hz and >14kHz..so I don't think that oscillation could improve the SQ so much..besides even after several days, the 1028AC are not warmer than my finger when I touch them. Well, he did a great job, and the socket stays...as I've got some chips to try anyway, like AD845KN and ADA4627-1B The new firestone models look cheapo to me, but the old models look very nice and sound fantastic to my ears(it had an OPA2604 stock, so it had to go )...it's also thanks to their DPS I'd guess, as we're mostly listening to the AC mains power as I understand it...one thing's for sure: I won't be using an SMPS anymore, it'd be a major nocebo for me anyway..oh ok, I always read that solid caps were a terrible idea for audio...and I tried this soundcard that had a very harsh and agressive sound I couldn't bear: http://c1.neweggimages.com/NeweggIma...271-005-04.jpg anyway, I'm still in the market for an AK4396/DIR9001/LT1028AC combo if anyone knows of one ![]() R2R is supposedly the highest grade of DAC you can buy: Mother of Tone - Conversion Techniques AK4396 is said to have the same SQ as R2R: DCX2496 Quote:
#1853 |
I've asked someone else, who tells me that sockets do add impedance...and I've tried to add a gold plated socket on top of the Spitfire's, and it sounds just like when I had sockets on the browndog...sound is less clear and "muddier".
so a wild guess would be that the impedance added by the stock socket was taken in account in their design...chick logic I know ![]() the Spitfire is not ventilated at all, and after several hours the 1028's were slightly warmer than my finger...something like 40/45C? I think that's fine. anyway, I will also try to solder some 1028AC's on this adapter: http://shop.diyrealaudio.com/product...roducts_id=851 this ebay seller says that the browndog's are worthless: http://cgi.ebay.com/10pcs-Dual-SOIC-...mZ230379640581 Last edited by leeperry; 22nd April 2010 at 10:57 PM. |
#1854 |
BTW, I was wondering, is there a single version of NJM4580? this one is really good to drive headphones
#1855 |
Just wanted to chime in on the OPA1611 that some people are raving about on this thread. We tried them in a critical listening test on a front-end all-diff discrete/IC gain stage (40dB) and rated them dead last. They shifted timbre far more than the other 5 devices under test. Another poor performer was AD8671.
That said, the 1611 might be a stellar performer in a different topology. As always, it depends on myriad variables, designer's goals, power options, etc.... |
#1856 |
I have just stumbled across this thread, so appologies if these have already been mentioned.
I like the LM4562 dual op amp. As a drop in replacement for my NE5532's (Phillips branded) in my NAD C520 CD player, they seemed to unearth a little more detail from the music. I have the NE5532's tucked away for a future project, as I still think they are a good op amp when implemented correctly. Chris. |
#1857 |
Hi Chris!
If you like the LM4562s, you really need to try the OPA2141. You'll need an SOIC to DIP adapter and a bit of soldering skill, but well worth it! Another goodie to try is the LM49860. That one comes as a regular 8 pin DIP and will be a straight drop in. The 5532s are still an industry standard, and, as you said, work great in the proper application. They're dirt-cheap too. ![]() Take Care, Dan |
#1858 |
LM series 61XX are worth trying.
#1859 |
Interesting....Which ones have you tried, and in what application?
Dan |
#1860 | |
Banned
LMAO Conclusion: You need a tube |
| -: Best audio OpAmps :- | audioPT | Parts | 62 | 9th April 2013 11:44 AM |
| The Best Sounding DUAL opamps | mudihan | Chip Amps | 214 | 1st May 2011 05:09 PM |
| best sounding Tx for sub 10watt class A audio amp? | mondogenerator | Solid State | 2 | 2nd October 2009 05:21 AM |
| Help the Idiot: Simple, Great-Sounding Integrated Amp Designs | SRMcGee | Tubes / Valves | 7 | 15th September 2005 06:43 PM |
