| Chip Amps Amplifiers based on integrated circuits |
#1751 | |
We are adding a 1k0 resistor and/or adding a 68pF/100pF cap to a system that already has an RF filter built into it. The roll-off frequency of this parasitic RF filter is determined by the source resistance/impedance (Rs) of each filter. The Pot has a source resistance for the downstream side of 8k//12k1 = 4k8 The parasitic capacitance (Cpara) after that could be 5pF or 10pF or 20pF. The parasitic RF filter is effectively Rs & Cpara. Before adding the extra components and assumed Cpara=10pF we have RC=0.05us. This will not be audible as an audio frequency filter. Adding a 1000pF (=1nF) at the RCA input is ludicrous. Try 47pF at the RCA socket and come back with your audibility results. Now add on 1k0, RC becomes 0.06us, still inaudible. Now add 68pF alone, RC becomes 0.37us, some may argue this is just approaching audibility. Now add 1k0 & 68pF, RC becomes 0.45us, even closer to audibility. Replace the stacked film low inductance 68pF PP with a rolled foil medium inductance 100pF PS and the filter characteristics will be changed. This may be audible. In addition the RC becomes 0.58us. This slope is modified by the inherent inductance of the polystyrene. I am not talking about swapping boutique /exotic parts for technically competent components. I am talking plain and simple engineering.
regards Andrew T. Last edited by AndrewT; 10th April 2010 at 11:20 AM. |
#1752 | |
We are adding a 1k0 resistor and/or adding a 68pF/100pF cap to a system that already has an RF filter built into it. The roll-off frequency of this parasitic RF filter is determined by the source resistance/impedance (Rs) of each filter. The Pot has a source resistance for the downstream side of 8k//12k1 = 4k8 The parasitic capacitance (Cpara) after that could be 5pF or 10pF or 20pF. The parasitic RF filter is effectively Rs & Cpara. Before adding the extra components and assumed Cpara=10pF we have RC=0.05us. This will not be audible as an audio frequency filter. Now add on 1k0, RC becomes 0.06us, still inaudible. Now add 68pF alone, RC becomes 0.37us, some may argue this is just approaching audibility. Now add 1k0 & 68pF, RC becomes 0.45us, even closer to audibility. Replace the stacked film low inductance 68pF PP with a rolled foil medium inductance 100pF PS and the filter characteristics will be changed. This may be audible. In addition the RC becomes 0.58us. This slope is modified by the inherent inductance of the polystyrene. I am not talking about swapping boutique /exotic parts for technically competent components. I am talking plain and simple engineering. Adding 1000pF at the RCA socket is ludicrous. Try 47pF and come back and tell us the audibility result. The reason for such a low value at the input is that a 2pole filter is being created using the inductance of the preceding interconnects to create an LC RF filter. The RF filter is not intended to alter and/or modify the audio signal. It is there solely to attenuate the RF interference and thus allow the audio circuit to do it's job properly.
regards Andrew T. |
#1753 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Aim at heaven and you will get earth thrown in. Aim at earth and you get neither. - C. S. Lewis |
#1754 |
Andrew,
I guess we have moved on from this. The roll-off is not an issue. See below. Right from the CD output to the opamp input. I have not included parasitic inductance and resistance. But you know they won't affect the result of the roll-off as much. I have made the capacitance to the extreme. Regards, Bill ![]() |
#1755 | |
You are losing me on your descriptions of your experiments ![]() You moved the RF shunt (68pf and 1k) to the front of the pot... that's fine, however the filter response is now determined more by what feeds the pot. I'm looking at your circuit in post 1707. If you feed it from the wiper of the volume control, then the source resistance alters as the pot is turned, this in turn has a small effect on the reponse of the filter. In other words the response is different for every setting of the pot... but the effect is slight with the values used. Feed the filter from the constant impedance of the CD player output and the response is "fixed".
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#1756 | |
Post 1754. Are R1, R2 and C1 inside the source CDP?
regards Andrew T. Last edited by AndrewT; 10th April 2010 at 12:42 PM. |
#1757 | |
I'm looking at your circuit and you feed the 20 k pot from the CD player output which will be at a fairly low Z.
#1758 |
Hi Alexg !
You are on the right track. Pannasonic FC is a good replacement and the sound may get a bit smoother over time. 0.47 uF seems a bit small to me. What is the input impedance of your next ( line ? ) stage ? For 47 kOhm i whould recommend something around 2uF. The RIAA curve in the V-LPS should be accurate. Those guys are not stupid but may as you say have used affordable components to keep the price down. |
#1759 |
Mooly, I guess we typed at the same time. Can you see post #1754?
#1760 |
A$nd you have just posted a new circuit
![]() 1nf is too high to use on the output of an opamp (in practice). Andrew keeps mentioning parasitic capacitance etc. That's one reason I mentioned earlier that this was a real world measurement taking into account the 'scope probe capacitance. I nearly posted another picture of the result at HF using a 1 to 1 probe to show you. When you are talking about small cap values (pf range) then circuit layout and stray capacitance starts to become more and more important... and you can even make small caps on the PCB using close running print, not just caps but inductors too, and this is often done in RF work. Back to audio...
| -: Best audio OpAmps :- | audioPT | Parts | 57 | 13th October 2011 02:47 AM |
| The Best Sounding DUAL opamps | mudihan | Chip Amps | 214 | 1st May 2011 06:09 PM |
| best sounding Tx for sub 10watt class A audio amp? | mondogenerator | Solid State | 2 | 2nd October 2009 06:21 AM |
| Help the Idiot: Simple, Great-Sounding Integrated Amp Designs | SRMcGee | Tubes / Valves | 7 | 15th September 2005 07:43 PM |
| Page generated in 0.31297 seconds (39.28% PHP - 60.72% MySQL) with 11 queries |
