Old 9th February 2010, 12:55 PM   #1681
Mooly's Avatar
Originally Posted by peranders View Post
Just a reflexion: Andrea talked about taste and replacing opamps. This is like talking about how good "surströmming" is to a person that either haven't tasted it nor will.
BTW: Surströmming is yummie, once a year at least
Surströmming - Wikipedia, the free encyclopedia
Surstromming--One of the World's Strangest Dishes
Surstrmming - fermented Baltic herring
I imagine that is something you would have to experience.
A simulation free zone. Design it, build it, test it.
Old 9th February 2010, 04:08 PM   #1682
QSerraTico_Tico's Avatar
Bork, bork, bork, bork
Old 16th March 2010, 03:25 PM   #1683
Sorry. I m not an expert. Can i ask to you ?
i have two opamp RC4588 in my Denon CD, can i use two LME49860 in upgrade ?
Need a different scheme around it ?
Old 26th March 2010, 11:52 PM   #1684
prairiemystic's Avatar
Default The NE5534 is dead
Just a reminder to everyone, the Texas Instruments NE5534 and NE5532 are ABSOLUTE GARBAGE . I have been literally kicked out of the recording studio after doing repairs with these parts. Noisy and trashy sounding at the best.
The proof the TI NE5534 has no relation to the Signetics NE5534 was in a product I worked on a few years ago that broke some rules. The design applied DC/AC to the compensation pins 5, 8 to shift the bias in the op-amp. The TI parts latched up whereas the Signetics parts worked fine.
When I contacted TI engineering, their reply was it's not exactly the same part but it meets the specs and is thus considered equivalent. The original NE5534 used some older IC fabrication techniques that is too expensive to continue.
I haven't tried these other manufacturers:
On-Semi, New Japan Radio NJM5534 (they sounded blah)
Be careful about the manufacturers of these multi-sourced parts.
Old 27th March 2010, 12:05 AM   #1685
Electrons are yellow and more is better!
peranders's Avatar
You could actually change the NE5534 to something similar and hopefully better. If the opamps are noisy as you put it, are you sure that the opamps is the cause of that?
/Per-Anders (my first name) or P-A as my friends call me
Old 28th March 2010, 08:26 AM   #1686
I had a similar expirence when I replaced all of the opamps in my fostex 454.
they worked fine in the signal path but turned the filters into vfo's and also some actualy worked in the filter sections but didn't sound consistent per section.
So I just used TL082's thourghout and it sounded way better than original stock.
It was as clean as my mackie 32-8.
Another time i was building a preamp or fuzzbox or something for my giutar or something and it failed miserably.Popped in a trusty TL082 and it worked prefectly with no changes.
After some research I found that it had something to do with bias current and had to be figured into the design, like ,to high of value in the feedback and it won't work at all.
That was 15 years ago and haven't touched one since.
I know there are some nice newer opamps out today,but you beat the old TL series bifets.
I used to cringe every time I'd see a schematic or buy some kind equipment that they would call professional and find a jrc45xx inside.
I got to the point were I could bet you what opamps were being used in it by looking at the spec's and hearing it was a no brainer.
As far as the NE5532 and NE5534 goes i had some that were nice quiet and and most of them were noisey and out of spec.
Very inconsistent.
But the ones that did work sounded great.
I know it sounded contridictory but i had more than just a couple them, as ther was like betwen 40 to 60 chips in that mixer and I bought them in seperate batch's. jer
Old 28th March 2010, 10:12 AM   #1687
wwenze is offline wwenze  Singapore
Would this apply for NJM vs JRC 45xx I wonder?
Old 28th March 2010, 11:53 PM   #1688
nad is offline nad  United Kingdom
2 months away, 169 pages later, OP Andrea banned (good) and it's still going with the same old same old flopamps, go discrete!
Old 29th March 2010, 01:49 AM   #1689
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Originally Posted by nad View Post
... OP Andrea banned (good) ...
How did that happen? He did not seem too bad back then.
Hear the real thing!
Old 29th March 2010, 02:18 AM   #1690
Joachim Gerhard's Avatar
I only have good experiences with Texas NE5534A and have used quite a few.
The A type has guanranteed noise and offset spec.
As a replacement i use LME49710 also. It even has (slightly) lower distortion and voltage noise but 4 times more current noise so as a bipolar the NE5534A is still special.
If i need higher speed i take the LT1468.
Used correctly the NE5534A is a very neutral amplifier.
Simply swapping OPamps without measurements or optimisation and giving them a absolute ranking is a bit mindless i think.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ztjangle
-: Best audio OpAmps :- audioPT Parts 57 13th October 2011 02:47 AM
The Best Sounding DUAL opamps mudihan Chip Amps 214 1st May 2011 06:09 PM
best sounding Tx for sub 10watt class A audio amp? mondogenerator Solid State 2 2nd October 2009 06:21 AM
Help the Idiot: Simple, Great-Sounding Integrated Amp Designs SRMcGee Tubes / Valves 7 15th September 2005 07:43 PM
Page generated in 0.15061 seconds (79.69% PHP - 20.31% MySQL) with 11 queries
