| Chip Amps Amplifiers based on integrated circuits |
#1671 | |
Audiotrak Prodigy HD2 Sound Card |
#1672 |
Hmmm, banned ... amazing, and no reason given
KL. |
#1673 | |
Account Disabled
- 3x Burson Dual Opamp - 7x 25V 470uF Panasonic FM (PSU filtering) - 5x 35V 470uF Panasonic FM (" ) - 6x 16V 4.7uF Sanyo Oscon SH (" ) - 7x 1uF Vishay MKP1839 (opamp/chip decoupling near the pins) - 7812ACV +12V regulator instead of standard 9V - 7912ACV -12V regulator - LT1086 +5V regulator for DAC analogue supply - 4x 470pF WIMA FKP2 for high/low pass filtering - 4x 10V 220uF Panasonic FC signal coupling now there's only the hd2 w/ huge transformers Source PC | Gooi PC's |
#1674 |
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#1675 |
ok ...
KL. |
#1676 | |
- Noise is fixable and dependent on the pc itself. This is a bit of a non-issue if you take care with your layout, components and settings. - THD is pretty much the same as stock. - The shunt regulator is just as close to the AK as the stock IC regulator. It's not 'external' I'd say. |
#1677 |
if anyone is interested i stabilized lt1028 using progressively bigger fkp wima capacitors between the overcompensation pin and the output (soldered directly on the dip8 package)
330-470pf is more then enough the sound is miles better comparing to a capacitor in the feedback loop but only a 22pf value in the feedback was enough to make it stable |
#1678 | |
Andrea managed to start a new opamp thread at diyhifi (which hosts some people banned here) the 4th of February and has been banned the 5th... ![]() A new world record?
Dario ClaveFremen "Bailando Salsa en el Sietch" |
#1679 |
He also managed to set up another account here under a different name for all of 5 minutes, also on the 5th... just long enough to send some PM's before being banned.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#1680 |
Electrons are yellow and more is better!
Just a reflexion: Andrea talked about taste and replacing opamps. This is like talking about how good "surströmming" is to a person that either haven't tasted it nor will.
BTW: Surströmming is yummie, once a year at least ![]() Surströmming - Wikipedia, the free encyclopedia Surstromming--One of the World's Strangest Dishes Surstrmming - fermented Baltic herring
/Per-Anders (my first name) or P-A as my friends call me |
| -: Best audio OpAmps :- | audioPT | Parts | 57 | 13th October 2011 02:47 AM |
| The Best Sounding DUAL opamps | mudihan | Chip Amps | 214 | 1st May 2011 06:09 PM |
| best sounding Tx for sub 10watt class A audio amp? | mondogenerator | Solid State | 2 | 2nd October 2009 06:21 AM |
| Help the Idiot: Simple, Great-Sounding Integrated Amp Designs | SRMcGee | Tubes / Valves | 7 | 15th September 2005 07:43 PM |
| Page generated in 0.12892 seconds (80.66% PHP - 19.34% MySQL) with 11 queries |
