| Chip Amps Amplifiers based on integrated circuits |
#1651 |
#1652 |
What's to explain, he's happy and that's all that matters. Those empty opamp sockets look cool.
I'm the most horrible I'm the most horrible |
#1653 |
Appears that he/she did:
- removed differential/LPF/buffer opamps. - removed coupling capacitors. - connected audio transformers to AK4396 DAC differential voltage outputs. - routed transformer outputs to card's RCA audio output jacks. In otherwords, transformer provides DC blocking/isolation, impedance matching, and LPF functions. - guessing output level is lower than stock. - typical transformer coupled topology. (of "no-opamp" ilk.) - tradeoff appears to be increased noise and THD. (long signal wires in noisy PC environment.) Power Section: - replaced various power filter capacitors with OSCON. - replaced onboard 5vdc voltage regulator(s) (for AK4396 DAC) with external shunt regulator. Amplimo TM20 Signal Transformer: - 30Hz - 25000Hz - price: approx $114.00 USD Last edited by bichi; 26th January 2010 at 06:27 AM. |
#1654 |
Banned
#1655 |
Banned
I bought me a very cheap (on offer @ 19.90€) "Sansui DV1200" DVD player, whose sound (after burn in & connected with the always dependable VDH The Bay C5 interconnect) I definitely like, for its warmth and fluidity, although it certainly doesn't do anything extraordinary.. It looks like a perfect base for some modding, though
![]() I will need to open it and see what DAC it has (provided it's even an independent DAC chip) to decide whether to use (most probably) OPA1642 or LME49725. Secondly, I guess I'll change coupling caps, and perhaps some power supply caps too.I like the amount of goodness you can buy today for 20€. Last edited by Andrea:; 26th January 2010 at 09:18 AM. |
#1656 | |
so you can replace op-amps by pricey transformers huh ![]() he's usually using Burson op-amps and already tried pretty much every op-amp in the book, I'd trust his judgment
#1657 |
I have seen data from some small integrated amplifiers, fed at low voltage. the Max, tda, ... tpy
Are there any integrated amplifier that can be used as a headphone amp for hd595, with high audio quality (above all). Or is it better to go directly to operational amplifiers for this application. The supply voltage would prefer that high, I have 22/0/22V in the transformer. |
#1658 | |
Banned
![]() Anyway the HD595 was driven well by opamps directly in my experience. I remember it sounding really good driven by the LT1361 (or two single LT1360). The OPA132 (singles tend to be a better choice for this) is a good candidate as well. If you try the LT1360/1, pay attention to DC offset
#1659 |
Banned
And... I just bought the parts (some 105°C electrolytics) to fix my "Xenos 1HA-EPC" headphone amp.
As for the opamps, I'd already soldered an LT1358 in the stage that drives the transistor buffer; and this will remain. And I'll use the OPA1642 as the input and gain stage. I'm sure they'll pair well ![]() That way I'll manage to try this OPA1642 that I'm curious about, and sooner than I would have in the said DVD. |
#1660 |
I have an old headphone amplifier circuit that employs the rc4558 dil-8, with a dc decoupling capacitors in and out. Gain 6. Could I use it with a more modern dual ao, what would you advise me?
I had given up using it because, from reading this forum, had figured that would work best to build a new circuit with two opa1611, and although more work (and money) might be worthwhile to design and build. (In order to improve the quality of sound.) The source I want to use is high quality and i want to make the best of it. Furthermore, no stone seen your note on the Yulong a1000, which ultimately is based on another dual, the OPA2134 + bc377 at very reasonable prices. You just have to ask ...and paid. |
| -: Best audio OpAmps :- | audioPT | Parts | 57 | 13th October 2011 02:47 AM |
| The Best Sounding DUAL opamps | mudihan | Chip Amps | 214 | 1st May 2011 06:09 PM |
| best sounding Tx for sub 10watt class A audio amp? | mondogenerator | Solid State | 2 | 2nd October 2009 06:21 AM |
| Help the Idiot: Simple, Great-Sounding Integrated Amp Designs | SRMcGee | Tubes / Valves | 7 | 15th September 2005 07:43 PM |
| Page generated in 0.13662 seconds (79.76% PHP - 20.24% MySQL) with 11 queries |
