help in building TDA7294
Old 15th December 2009, 04:45 AM   #11
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Thanks man!!
Something to add: Bootstrap cap = 47uF. The 22uF in the datasheet makes for lousy bass as the 22uF pictured is "perfect cap" and doesn't represent "average electrolytic" So, it would be 47uF for average electrolytic, unless your speakers are smaller than 6"
Old 16th December 2009, 09:40 AM   #12
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I don't know if that was exactly the fault, but a few years ago (when I knew much less about electronics) I built some TDA7294 chip amps and I got blown ICs at first while I was leaving the mute/standby inputs floating (with the RCD networks in place).
Actually I was charging the capacitors by feding 35V to the mute/strandby PCB inputs and then leaving them open. The capacitors would take several minutes to discharge to the point where the sound starts fading and then... humm!! and blown IC.
I use to feel like the small child in The Emperor's New Clothes tale
Old 16th December 2009, 03:29 PM   #13
pra3718 is offline pra3718  India
so i dont know i might stick to my TDA7265 ( 25 +25) as i find it a bit expensive for the speakers
Aditya, TDA7265 is available in indian local market? What is the price of ? Where are you from ? This chip If remember used by altec lansing.
Old 16th December 2009, 03:44 PM   #14
nhjsdfops is offline nhjsdfops
Old 17th December 2009, 12:20 AM   #15
sexya is offline sexya  India
Send a message via MSN to sexya Send a message via Yahoo to sexya
hii
in bombay go to amar electronics, he used to sell them for some thing like 50 to 65 per peice, i want to konw where i can i buy LM1875 in bombay, and which is better lm 1875 or tda2050,
Old 17th December 2009, 08:07 AM   #16
pacificblue is offline pacificblue  Germany
That must have had a different cause, because what you describe is exactly, what the datasheet shows. Close the switches and charge the capacitors to any voltage between 3,5 V and 40 V to unmute. Open the switches and let the capacitors discharge to below 1,5 V to mute.
Which means, my former post is wrong. You do need voltage on those pins to operate the amplifier. So, if you don't want to use the suggested components from the datasheet, because popping noises don't bother you, you need to connect the stand-by and mute pins to the positive rail. Leaving them floating or grounding them means the amplifier will be muted and in stand-by.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 17th December 2009, 09:04 AM   #17
hii
I never try lm1875 but experienced member says lm1875 is good. I experienced tda2050 and it is good for low frequencies.
If you refer ESP's project 72 In circuit description on 2nd para "You can also use the TDA2050 (from SGS-Thompson), which has almost identical performance and (remarkably) the same pinouts! "
Now I wish to use tda7294 for woofer either mono or bridge. I am looking for best suitable circuit with minimum components.
Old 17th December 2009, 10:35 AM   #18
Aditya, What do you think about attached picture ?
Old 17th December 2009, 05:23 PM   #19
nice. i did find a onlie solution check out a chinese website called gorge and charle's. i found two tda7294 layouts and u can convert the page using altavista language convertor. - babel fish
the link is ---- 喬治查爾斯電子電路網 check out and the pdf at the end of each article has a pcblayout which is ready for tonner transfer,
i m though making a tda7294 pcb layout for my self, you see i have put one of the designs as an attachment, on the first page of this post.
where are you from as in which city,
Old 18th December 2009, 09:54 AM   #20
Hi, I am from Nagpur (2nd capital of Maharashtra). Your link is very good. Thanks. This time my project is tda7294 subwoofer.
help in building TDA7294Hide this!Advertise here!
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 06:58 AM
My TDA7294 Amp panson_hk Chip Amps 1 27th June 2007 01:06 PM
Need help on tda7294 amp Fossil Chip Amps 6 20th April 2005 02:53 PM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 02:08 PM
