| Chip Amps Amplifiers based on integrated circuits |
I make a headphone amps of clips, it is OP+BUFFER (OPA637+ BUF634) The PSU is LM317/337.
Power to OP have what is being proposed? This is my PSU,50W AC25V /2 ,SPRAGUE10000UF /2 TRACK,LM337/317. |
#2 |
ALL INSIDE:
#3 |
frugal-phile(tm)
Kool... How does it sound?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Banned
Hi digi01
Very cool, that headamp. But allow me to make some suggestions: The buffers are far from the op-amps. Are they inside the feedback loop? The op-amps (and the buffers) also seam to be poorly bypassed, the caps are far away from the supply pins... |
#5 |
planet10
this amp isnot completed.Thank you carlosfm ,Your suggestions is very helpful to me. One that is because of the op pins very small and exquisite, can't as big chip of GainClone p-p weld , so the overall arrangement is really very difficult This is my PCB bottom : |
#6 |
How did you make that pcb ??
is there any reason behind those massive traces ? |
#7 |
I have consulted the structure of EVM PC BOARD of TI, signal ground , power ground , and shielding ground is separated.
PCB was carved with the craft knife
#8 |
#9 |
Finally, I finished it.AC PSU +- 15V,single loops GAIN=11.
CHIP is OPA637AP+BUF634. Sonud is excellent:") |
#10 |
update,reset GAIN=4.5,input op use two AD8610. I seperate the signal grounds and power grounds use a 5ohm resistor.
The sound of BB chip is relatively dark, fine and smooth.AD8610 can let 495 represent more enthusiasm,YEAH! I like it. |
| Hi Fi Plan | billyisgreat | Solid State | 6 | 29th March 2007 04:03 PM |
| my opa548 headclone for AKG-K1000 | digi01 | Chip Amps | 14 | 24th February 2004 07:19 AM |
| Page generated in 0.08102 seconds (84.53% PHP - 15.47% MySQL) with 11 queries |
