What to use for TO-220 isolating pad? - diyAudio
Old 20th May 2003, 08:49 PM   #1
leadbelly's Avatar
Default What to use for TO-220 isolating pad?
What are you guys using to isolate your wide TO-220 packages like the LM3875?
Checking stores, all I can find are the thin flexible TO-3 pads (wrong shape) or the thick aluminum oxide for narrow TO-220 (too narrow).
Is there something more specific out there which I can't find?
How crazy would it be to drill 2 more holes in the 3875 and just use 3 TO-220 insulators?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 20th May 2003, 09:15 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
The ultimate in DIY!!! It would be like drilling holes in ones brain to fasten its head before going under a scanner.
There are silpads available in larger formats (100x100mm) which you can cut into the desired format. Your local supplier must be able to provide them.
This for example: http://www.angliac.com/product_searc...cat_number=500
/Hugo
Old 20th May 2003, 09:46 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I'm using TO-220 aluminum oxide pads under LM1875. It works fine and sounds better than silpads (less damping, I guess, results in more airy sound).
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 20th May 2003, 09:57 PM   #4
leadbelly's Avatar
Peter, do you mean just the regular narrow TO-220 pads? So you are experiencing no issues with having some of the LM3875 mounting surface not in contact with the pad? If so, I would love to hear it!
Old 20th May 2003, 10:04 PM   #5
UrSv is offline UrSv  Sweden
UrSv's Avatar
Peter was talking LM1875 which is in TO-220. LM3875 is in 11 pin MultiWatt which is small enough to fit on a TO-3P (not TO-3) pad. To use TO-220 pads under a LM3875 seems pointless since TO-3P are readily available. The MultiWatt size is hard to come by and the only place I've seen it is Schuro.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 20th May 2003, 10:17 PM   #6
I got everything mixed up. I meant LM3875 and TO-247 pads pictured below. They measure 14 x 19.5mm and I think are sold indeed as TO-220, but fit TO 247 and are the same as TO-3 P (I guess). The sides of a chip are sticking out a bit, but I didn't have any problems because of that so far. I really like to use those aluminum oxide pads here, as I said before, they sound better and provide extra clearance between heatsink and pins for a feedback resistor.
www.audiosector.com
Old 20th May 2003, 10:21 PM   #7
leadbelly's Avatar
Woo-hoo...thanks Peter, I already bought some of those
Old 22nd May 2003, 09:41 PM   #8
rljones is offline rljones  United States
I've used the Multi size, like digikey part BER118-ND for the LM3875 or the TDA7294. A less expensive option is BER190-ND in the same size.
regards, robert
Old 23rd May 2003, 08:41 PM   #9
cm961 is offline cm961  Canada
cm961's Avatar
These chips are availible in isolated packages, you could try that.
LM3875TF intead of LM3875T.
Hope that helps.
Pete
Old 11th July 2003, 03:03 PM   #10
Matttcattt's Avatar
i used top3, and made a new hole, they are the perfect size. they are 22mm by 18mm, i just turned it sideways and made a hole at the top. see image.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Isolating a hum? Bogie Solid State 10 26th January 2005 02:14 PM
Isolating each Mos-Fet? richeros Solid State 14 13th April 2003 11:19 PM
Copyright ©1999-2017 diyAudio
